Sigh. Rounded out oil tank plug
Trbayth
Even having the right tools and knowing what to expect, I managed to round out the oil tank plug. Not sure if it's BRP using the cheapest parts they can get away with or the dealer using a pneumatic air hammer to tighten it when they did the break in service.
No problem with the crankcase plug. No problems with the filter covers.
Off to order some Gold Plugs...
Bummer..!!
sometimes its a one shot deal. Hot oil on threads can crystalize like locktite. If you don't tap on it to break it loose and get a good stiff pull with a good socket allen you will strip it out....not sure why they go with allens and torx other than recessed but they have the room...:banghead:
Now the one to really watch is the radiator drain plug...:yikes:
Mechanical advantage
In addition to the coolant acting like locktite, compare the size of the Allen portion of the plug to the diameter of the plug that contacts the motor or tank. The Allen is much smaller, thus giving the plug the mechanical advantage. The Allen will wring out most of the time.
