Seeking wisdom from the list about how best to lift the front with a jack?
It's not excessive it it takes that much to balance. This amount is not uncommon when running Kenda's. We've seen more.
~~~I could run 90 MPH with both hands off the handlebars and Cretin Girl ran straight and true so the tire/wheel was balanced and the alignment is right on the money. That was before I lost all the air pressure in that tire then rode it 3 miles home totally flat which ruined the tire and why I am R&Ring the two front tires. I learned a good lesson that day. What I should have done was to call Mrs. Jake to have her come fetch me, leave Cretin girl on the side of the road then come back with my dump trailer and haul her home. This is how some of us learn
I’ve hung out here long enough to know others have had less favorable views concerning Kenda tires yet I’ve had nothing but praise for the Kenda tires on this 2021 Spyder RT Limited plus the Kenda tires on my 2020 Ryker Rally were equally impressive
That said, I bought a set of dark side tires this time around for the replacement tires
Best,
Jake
Reddick Fla.
It’s never too late to have a happy childhood
Great advice Gwolf & 2dogs. I like the compact scissors jack idea but, Jake is a little impatient tonight so e’s likely going to wing it wif the monstah floor jack, to R&R at least 1 wheel. Seriously good advice all around concerning the leather bits
Where I’m slightly stumped (NOW)… I have a butt load of miscellaneous sockets. I’m trying to find the best fit for the lug nuts. 1st place so far goes to a 6 point 13/16 ths. What are others using to R&R the lug nuts?!?
Best,
Jake
Reddick Fla.
We always like a bit of volume- Phil Campbell
Try a 21 MM socket.
Try a 21 MM socket.
~~~I’m guessing the 21mm socket you have is a 6 pointer. I have several 21mm sockets but, they’re all 12 points and they have too much slop to afford a good fit. Fortunately the 13/16th’s 12 point socket I’m using is a better fit
Best,
Jake
Reddick Fla.
You know the old saying, if the shoe fits wear it!!! Put them nice tires on and start riding!:coffee:
Best,
Jake
Reddick Fla.
I don't remember. I got 5 or 6 different sets in half inch drive in both 6 point and 12 point. I may have used a 6 point . Probably got it out of which ever toolbox was sitting the closest to the Spyder. I would have grabbed a metric because most everything on the Spyder and the New Holland is metric. The Harleys are mostly SAE and the trucks are anybodies guess. It depends on what part it is. I got a Gas Monkey shop stool with wheels on it that has metric in one drawer and SAE in the other. Some guy was standing in my shop waiting for me to weld something for him and he said I had too many tools. I told him there was no such thing as "Too Many Tools". That is an evil rumor started by women with 50 pairs of shoes.
From what website did you buy the Vredestein tires?
Also, keep in mind the 175 width tires are 10mm (about 3/8") wider than stock Kenda. They will probably rub the inside of your fenders. Just sandwich two 5/16" washers in between the steering knuckle and and each of the four fender mounting braces. It's easier to do while you have the tire off for change out. Make sure to roll over the new, wider tires by hand to verify they don't rub.
Thought you were putting on Vredestein tires! or maybe you clean up them Kenda tires so the recycling man will take em.
~~~the Vredestein Quatracs will be the new rubber on my Spyder rims. The tire you see in post #27 is the OEM tire after some cleansing. I don’t care to work with dirty parts, tires, what have you, and probably why I could never make it as a mechanic. I’d spend too much valuable time cleaning things
Best,
Jake
Reddick Fla.
~~~Tire Rack
~~~I don’t believe there will be any clearance issues with the tires I purchased. There’s been plenty of peeps here that used the exact same tires & I don’t recall any of them having to shim fender stays. Thank you for your input just the same
Best,
Jake
Reddick Fla.
Even a blind squirrel finds a nut every once in a while
~~~too cold to work in the garage tonight so I brought the work indoors in front of the wood stove. Well I’ll be a son of a buck. Despite lubing the tire beads/rim with a quality tire lube I can’t get any of the tire bead up over & off the rim. I’ve been doing my own motorcycle tire work since 1975, including the wire spoke wheels/tires on a 1964 MGB we owned for a long tome. Those MGB tires though were tubeless yet for the life of me, I can’t get these Kenda tires off using hand tools (tire irons) so, I guess I’ll have to take the wheels to a shop with a tire machine. Fortunately for me, one of those places is less than a mile from home so all is not lost
Best,
Jake
Reddick Fla.
Any man who thinks he can be happy and prosperous by letting the government take care of him better take a closer look at the American Indian - Henry Ford
.... Well I’ll be a son of a buck. Despite lubing the tire beads/rim with a quality tire lube I can’t get any of the tire bead up over & off the rim. I’ve been doing my own motorcycle tire work since 1975, including the wire spoke wheels/tires on a 1964 MGB we owned for a long tome. Those MGB tires though were tubeless yet for the life of me, I can’t get these Kenda tires off using hand tools (tire irons) so, I guess I’ll have to take the wheels to a shop with a tire machine.....
It doesn't really look it, but it's hard to see the detail in the pic displayed on my phone.... But is it so difficult cos the bead won't break; or that you can't get enough leverage on the tire irons to get the broken bead up, over, and off the rim?? :dontknow:
If it's the former, it's probably just their dodgy cheap arsed 'factory assembly' with little or no lube (no help to offer you with this, except maybe adding a length of pipe over your bead-breaker's lever/handle to extend your leverage ;) );
the latter, it's probably because the rims have very little 'well' for the other side bead to drop into in order to give enough 'free diameter' in the bead you're trying to lever over the rim edge so that you can get the tire off the rim!
This latter thing is a common attribute of 'J' type rims, which have 'deeper' bead sections on the rim in order to maximise the friction on the tire bead, stiffening up the sidewall and limiting the tendency of the tire to deform during hard cornering.... (and usually degrading tire performance somewhat along the way! :shocked: ) which is clearly something BRP needed to do for the very lightly constructed OEM Kendas in order to keep them safely mounted on the rims during hard cornering!! This 'deeper bead edge' on the rim forces you (or whoever is dismounting the tire) to be very careful about where that 'other' tire bead is sitting when you try to lift a bead up and over the rim edge - if the 'other' bead isn't absobloodylutely in the deepest part of the rim well, it's bloody hard if not impossible to get the levered bead up over the rim edge and therefore the tire off the rim without either reeeeaaalllly long tire levers (or 'greedy bar' type lengths of pipe/tube slip-overs to extend the leverage on the tire lever - just be careful not to bend the levers too much if you choose this option! :p ) or hydraulic assistance!! And for some reason, I've found this is especially the case with the OEM Kendas, not quite so much or so often encountered with a/mkt auto tires and their stiffer/better constructed sidewalls. :rolleyes:
However, I have found that when all other (manual) efforts fail, once both the beads are broken, it's pretty easy to get an OEM Kenda off the rim without tire levers &/or hydraulic assistance - simply put, a demo saw/reciprocating saw with a general-purpose metal/wood/plastic blade inserted usually takes just seconds and requires very little effort on your behalf to remove any OEM Kendas! :yes:
Simply cut the tire off the rim; one bead first, cutting away from the rim & being careful not to hit the rim with the moving tip of the saw; then running the blade out thru the near sidewall, the tread, the far sidewall, then finally the other bead, again cutting away from the rim and being careful not to hit the rim with the saw blade. :thumbup: It's just easier that way, and really, you're not gonna be keeping that worn Kenda to use again, are you?? :rolleyes: So why expend any grunt/effort on swinging the tire levers when a reciprocating saw makes such easy and short work of it?! :dontknow: AND, it also serves the purpose of opening up the tire so you can clearly see how lightly made the Kendas are, and if you choose the right spot in the tire, you'll often also get to see any defects in the construction of that particular tire. Plus, it gives you the satisfaction of cutting another bloody crappy Kenda up while you do it.... :thumbup: But maybe that last bit's just me?! :p
Just Sayin' :rolleyes:
Peter!, I enjoy your enthusiasm, but first, to answer your question, I broke the beads on both sides of the rim/tire. The problem is there is no well in the center of the rim for the opposing side of the tire to drop into, allowing slack if you will in the bead, so you can get the bead up, off & over the rim
I’ve read your post several times so it must be my thick Dutch skull that isn’t quite understanding how I could cut the tire bead w/o contacting the wheel using a reciprocating saw
Best,
Jake
Reddick Fla.
... I broke the beads on both sides of the rim/tire. The problem is there is no well in the center of the rim for the opposing side of the tire to drop into, allowing slack if you will in the bead, so you can get the bead up, off & over the rim
I’ve read your post several times so it must be my thick Dutch skull that isn’t quite understanding how I could cut the tire bead w/o contacting the wheel using a reciprocating saw ....
Yeah, that 'lack of a well' in the centre of their 'J' type rims is something else BRP may have done to make it harder for 'non-dealers' to change tires :mad: I haven't seen too many 'non-BRP' J type rims that DON'T have a well in the rim in order to make it easier to remove/fit tires, and almost all of those without a well that I HAVE seen with this design flaw (or deliberate action for whatever means) have been on Can Am machines! :banghead: :cus:
As for cutting the tire off, I've found that once I've broken the beads (both sides) I can drop the wheel onto the ground on its inner edge, then by using one foot to press the upper bead down into what little well there is and inserting the blade tip from above (at maybe about 80° to the tire tread, so the tip is juuust pointing into what little well there is... :rolleyes: ) and using just the tip end of the blade (with the cutting edge facing away from the rim) it lets me cut thru the bead without hitting the rim at all. Sure, it is something that you need to be very careful with while you're first doing it, and if you're not pressing down hard on your foot on the tire, it can jerk the tire all over the place, but if you've got a good grip on the saw, maybe even got it braced against your other leg, it does work once you grasp the concept & work out how hard to hold it. :ohyea: And if you don't do it/hold it properly/hard/tight enough to start with, then because of the angle you're holding the saw at, while I'm pretty sure I've never hit a rim yet, I'd suggest that any 'inadvertent touches' that the saw blade tip might make on the rim will be inside the well and minor at best, if it touches/marks at all at all, but as I said, I don't recall ever doing that anyway. :thumbup:
Mind you, IIRC there was a time waaaay back in about 2013 when I put a small maybe 1" long piece of garden hose split lengthways in one side over the very end of the saw blade, so that it covered maybe almost an inch of the solid back/end bits of the blade that might touch the rim, not on the blade at all, but I rapidly found that doing that was more trouble than it was worth, and I've never done it since. Your call on that tho. However, if I'm going to be cutting a few tires off rims that I don't want to damage or even touch with the saw blade in any one session, then just to make it a little less 'iffy' if I do get tired of holding the saw so tight, I still might cut a maybe 10" by 8" section of tread out of the first tire I do for the day (or I cut a section out of any other dead tire that's handy ;) ) and slip it into the little gap formed by pushing the tire bead down into the small well that's exposed, so that my section of cut tread can protect the rim from any inadvertent saw blade touches. Then I do all the cutting AWAY from the rim - upper side bead, sidewall, & maybe half of the tread first; then flip the wheel over and repeat the process from the other side, still cutting away from the rim all the while! When I'm in the groove, it takes about 30 seconds a tire, but it usually takes me a few to really get into the groove like that... Still, while it might take almost a minute for the first tire in any session, it's still a LOT easier than trying to get the bead up and over the rim edge, especially when it's on a rim with no well like those on our Spyders. :banghead:
Over to you. :2thumbs:
i have an idea most reading what you wrote (your last 2 posts) prolly think you’re off yer nut Peter, OTOH, after imbibing a couple Voodoo Ranger Imperial IPA’s, it snot so far fetched. That said, once I start drinking I put the powder tools away, and why (one of the reasons) I still have all 8 fingers & 2 thumbs on both hands. I like what you had to say Peter, the way you take the tires off with the rip saw, especially the bit where you said you remove an 8 by 10 inch section of tread then inserting it between the bead and the rim insures the blade stays off the rim, I can see that clear as day. What really motivates me trying your way is I wouldn't have to hand the work off to someone else
Best,
Jake
Reddick Fla.
Poke some holes in the edge of the old tires just above the bead, then zip tie the beads together with the heavy duty Zipties. After you get the beads pulled together as far as they will go, you should be able to angle the tire on the rim enough to get one edge off the wheel. I used to Zip Tie all the motorcycle tires together going all the way around. Most of the time they would slip on and off the rims without even using the tire spoons.
Jake, very odd you are not finding enough drop center with your rims. A couple years ago, on my friends Spyder, and his too is a 2021 RT Limited in Chalk color, I changed his tires.
Similar to what you are doing, manually broke the beads on both rim flanges of each wheel assembly. Used a 5 gallon bucket and rested the wheel assembly on the bucket. Quick squirt of WD around the old tires bead. Push the tire down to the drop center, and my short moto tire irons easily lifted the tires beads over the rim flanges.
Then installed his new Federal Formoza front tires, Dynamically balanced both and installed back on the Spyder.
Very odd you may need to resort to cutting off a Kenda tire. Every one I have replaced, by manually changing, has been a soft, low strength tire casing that easily removed from the rim.
All the best with it, and be careful as you cut the tire off.
~~~PMK!, Thank you for participating in my thread. The more, the merrier! Peter didn’t ask nor did I mention, when attempting the dismount, I chose to start on the inboard side of the wheel. The outboard side, upon further examination has a bit of a well as you mention, close the edge of the rim. If you got the bead up and over with (as you stated) with little effort, then there is no reason I can’t do the same, unless they Spyder your friend has is equipped with different rims, not exactly an unheard of scenario. BTW, I was surprised to find the word (CHINA) stamped in the middle of the hub area (inboard) on the one wheel I have removed. I realize the Spyder is a world bike yet I was taken back finding that the wheel was manufactured in China
While I have your ear…did you use rim protectors along with the tire irons you used?
Best,
Jake
Reddick Fla.
When I installed 175/55R15 Kumho Solus on my '21 RT Limited, they rubbed the fenders. Maybe your new Vred's have a different profile and won't rub. It's hard to tell without seeing them inflated, but they look to be more rounded at the edge vs mine. The Kumho is very flat across, and they definitely rubbed. Nothing a few washers couldn't correct.
Good luck!
~~~forgive me but, I’m having a hard time envisioning what you are saying. Any chance you have a pic of this you could post? Thanking you in advance!
Best,
Jake
Reddick Fla.
