I think the green and red ones are a different thickness ............ Mike :thumbup:What do the colors mean for the o rings? I received my oil change kit today. I am doing my own oil change tomorrow morning what do the different colors mean for the O rings? I have green, red and black
If you're using BRP parts, the green O-ring is the larger of the two that go on the oil sump plug ant it should go in the groove closest to the plug head. Using other than BRP parts, as others have said sizing them is easy and the fatter one goes closer to the plug head. The threads on the OEM plug are very sharp so I put painters tape on the plug before installing the O-rings and install the ring farthest from the head first so you don't have to dig the fatter one out of the first groove on its way to its proper groove.
Well I got everything set up and put a mirror under the drain hole so I could see which one was allen and which was torx and found out the allen looks rounded. the allen fits in it though. hummm my 9000k service last year gave me something xtra. thanks for the advice, I appreciate itIf you're using BRP parts, the green O-ring is the larger of the two that go on the oil sump plug ant it should go in the groove closest to the plug head. Using other than BRP parts, as others have said sizing them is easy and the fatter one goes closer to the plug head. The threads on the OEM plug are very sharp so I put painters tape on the plug before installing the O-rings and install the ring farthest from the head first so you don't have to dig the fatter one out of the first groove on its way to its proper groove.
thank you. my husband and I went to home depot and bought a 1 1/4 to 1 1/2 in toilet plumbing, a straight flexible rubber dohicky(dont know the proper terminology) that is 3 inches long for $3.99..that went up in the hole and caused the oil to run straight out not on an angle. I will put a picture here of the item and how we notched it to fit, when we actually do the oil change. We bought an oil pan from pep boys that actually catches the oil from both drain plugs. We had to get my bike set up on the lift table today first. On the lift table we used two ramps rated at 13000 lbs for $39 from harbor freight and a scissor jack that came with the lift table to level the bike so the oil will drain better (he says), tied bike down to keep from moving because we found that the brake only engages the rear tire. We did not know this. Its a learning experience. My next question was is there a sequence for removing the trans oil plug and reg oil plug. just asking. riding tomorrow and doc appt thurs...so this oil change has been backed up to Friday morning...I still need an 1/2, 6pt, 36m socket to remove the oil filter cap???? and yes we are changing the fuel filter while the tupperware is off. not using those fakaka clips though bought some fuel injection clamps.I think the green and red ones are a different thickness ............ Mike :thumbup:
by the time I get through asking all the dumb questions no one thought, knew or were afraid to ask this should be a good link for info on changing oil on a 1330.It would be really nice if someone would create a tip list when doing oil changes for those of us who have no experience and no one close by in case we get into a bind.
ray:
I got my kit from Baja Ron yesterday. looks like Blueknight is right, the red ones are thinner than the black ones. there are different sizes of each color for the 2 different size plugs. Also a copper washer and an aluminum crush washer it looks like. Its not rocket science, just mach the size to the plug. What is more important is to use the right tool to remove the different plugs to avoid stripping the plug and seat the toll all the way in before cranking it. One is an allen, the other is a torx.
...My next question was is there a sequence for removing the trans oil plug and reg oil plug. just asking...
How about that 36mm socket 6pt 1/2 in drive for filter cap...do I need a low profile for that or will regular do the job?
questions I have questions...lol sorry....if its an inconvenience...
Waiting on 36m 1/2 drive 6pt should be here tomorrow. Thanks for videoSince you purchased a drain pan that allows you to drain both plugs at once you're in great shape. There is no sequence on which plug to do first but you will get more out of the oil sump plug.
A standard 1/2" drive 6pt socket and ratchet is fine for the oil filter cap. Be certain not to put the clutch cover plug back in until you have opened the oil filter cap. When you do open it you will hear more oil running into the drain pan and there will be only a little left in the oil filter canister to wipe out.
If you watch Shawn Smoak's video at this link,
https://www.youtube.com/watch?v=ZPeb1YqV4Gw&feature=youtu.be, you will learn a short cut that saves having to remove the right side body panel; it's very handy.
I had the same question first time I did the oil change. One of the drain plugs has two o-rings. The other two go on the shaft of the oil filter cap. I put the plug and shaft on my work bench with the old rings still in place and compared them with the new ones. It was fairly apparent which ones went where, although the colors don't match.What do the colors mean for the o rings? I received my oil change kit today. I am doing my own oil change tomorrow morning what do the different colors mean for the O rings? I have green, red and black
These are the O-rings; note the different sizes (very slight)
This is the oil filter canister cap with O-rings on the shaft. There may be a difference in size, but I couldn't really see it.
This is the drain plug that has two O-rings on it. If you look closely, you can see the O-ring grooves are slightly different diameter.Can we reuse the O'rings if the Orings are not cut or damage?
