SE5 Issue & Blown Oil Filter
The glue that held the end cap on came undone nothing more than that.
I have seen this several times in the Sea-Doo watercraft I have owned over the years and in the watercraft forums too.
While the outer filter housing is in place it holds the end cap on the filter. Then when the filter housing is undone this cap sticks up inside the housing end cover because it was no longer glued on tight.
The glue's bond to the smooth metal filter end cap sometimes comes undone due to operation, heat, oil, and other things it comes into contact with.
As long as the filter cover was bolted down it pushed on the end cap and held it in place so the filter worked as normal.
Once he loosened the bolts and removed the filter housing cover is then when it pulled off the paper filter element, leaving it as it looks now.
New filter, clean oil and he'll be as good as new. :thumbup:
MM
The correct Spyder oil filter is not open at both ends. We have SMs, so I am not sure about the transmission filter.
This one wasnt
This filter originally wasn't open at both ends. One end was open with a rubber ring around it that went into the motor. The other end originally had an end cap on it that (IMHO) looks like it was blown off. If you look at the original pic closely, you can see where it looks like the end tore away from the filter. When I opened the housing, it didn't feel like it was stuck besides by the bolts, but I could be wrong. I didn't even see the end cap at all until my brother wiped the housing out & noticed oil kept seeping from the base of the housing. That's when we took a small flat head screw driver & had to pry the end cap out of the base of the housing. That's when I had my OH SH:cus: Moment :yikes: & new something was seriously wrong :gaah:
But as MagicMan stated, it could be as simple as the glue gave way when I
pulled the housing off. Tho, that wouldn't explain why I was having major
shifting issues the week before I discovered this :dontknow: and now that I
have a new filter & oil change, all seems well with the Spyder once again :yes:
Seems to me that the filter for some reason blew:yikes: it's top & that's what
was causing my shifting issues cause the oil wasn't be properly filtered thru
the filter causing pressure problems. I'm no professional:dontknow: and I don't pretend to know what happened. I just follow the realm of logic & to me, from what I've seen & experienced, this is what seems logical, tho I can't explain how or why.
Again, I appreciate everyones thoughts and opinions on this & by no means do I wish to offend anyone.
The problem is the top can't be blown off, there is nowhere for it to go. It makes a lot more sense that the glue came undone and the cap came off in the cover.
As far as your shifting problem goes, did you check the oil level before you changed your oil? Low oil will make a SE not shift right.
To stop everybody from worrying about this, I did some R&D in the shop. This time the "D" being for DESTRUCTION. :yikes:
I took a brand new BRP oil filter and used some heat to soften the glue and removed the end cap.
As you will see, the number on the filter RB-X341 is the same as the filter he has. The other number on these filters is the production run number and is used to know which batch they came from.
With the end cap removed you will see it looks just like his filter except this one has not had any oil on it yet and the glue is a bit dark from the heat I used to remove the end cap.
Lamont is 100% correct! :2thumbs:
When the filter is in the machine and outer filter housing is bolted in place it pushes on the end cap of the filter making it impossible for the cap to come off the paper element while the outer housing cover is in place.
It is only when you unbolt the outer housing cover that the end cap if not glued on tight could stay stuck in the outer cover.
Like I said before, use a new filter and some clean oil and you'll be OK. :thumbup:
MM
Hail to 'da MAN
WOW, Magic Man thank you so much for going thru the trouble of even destroying a filter to help get this answer right :firstplace:
I'm so impressed with your commitment to help all of us get the answers to our problems with our beloved :spyder2: THANK YOU!!!
I figure next week I'll change the oil, filter & this time, the SE5 tranny filter as well just to make sure any contaminants (loose glue :dontknow:) are totally flushed from the system. Any other recommendations?
No problem! :2thumbs:
I know how something like this can weigh on your mind as the not knowing for sure is the worst part. So with the holiday coming who needs to worry about things like this. So off to do some "D" testing I go! :ohyea:
I also know sometimes things like this can be like a snowball rolling downhill and get made bigger than they really are. :yikes:
I hope you can now rest a bit easier knowing for sure what it is you found, and once you finish your oil change you'll be OK. :thumbup:
MM
Great thread... Just a small question...
When this happens, is any oil able to bypass the filter and therefore be unfiltered and going back into the engine?
Or is this like many other "Filter covers" that are actually creating a pressure that holds the filter in place and snug, and no oil gets through without going through the filter?
I have not yet changed our oil on our RT-S. Per our purchases agreement, our Dealer has done it both times so far, so I have no personal experience as of yet with this to reference knowledge from. Yeah I have three oil changes worth of oil sitting on the shelf... But that is it... lol
Question...
Post number 7 picture number 1... is that filter installed backwards?
I'm still under the influence of surgery drugs and not seeing very good... so someone tell me am I seeing it correctly? ken krb1945
Its great to see someone going the extra mile and ease someone's concern. That's why I love this forum so much more than any others.
It is all the people like you guys that make SPYDERLOVERS.COM :2thumbs: :firstplace:such a great and informative place to come and get answers and share thoughts :chat:
So Thanks Everyone:ohyea:
:ohyea:
I think if you would have sent that filter to MITH BUSTERS, Instead of heat they would have done the job with a little Black Powder.:yikes:
Nope, its Not Backwards
Thats what I saw when I did my oil change. Thought the same at 1st, but ends up that when I pulled the Oil Filter Housing off, the Oil Filter End Cap must have came unglued and the end cap was stuck to the bottom of the housing, leaving behind what you see in the pic, an open ended filter.
So, all in all, it wasnt backwards & due to MagicMans resourcefullness we deducted that it wasnt blown either.
Hope your feeling better soon KRB & HAPPY HOLIDAYS.
