Ryker throttle grip pulled out - does it snap back in? Or how does it go back??
peacons
The ham-handed movers who we had moving our household goods and two Rykers managed to pull the throttle grip out of the housing on one of the Rykers, leaving just the inner metal tubing. How do you get this back in place? Does it just snap in, or is there some voodoo you have to perform to get it to work properly again?
I'm a little unsure of the exact problem, but if the throttle grip has come out of the housing, you will need to unscrew the 3 retaining screws to refit it. I have attached a picture of the inner workings if that helps. Take it slow, it's a fairly simple setup, so you should easily get it back together... provided they haven't busted anything.
