RT622 Trailer LED
fastfraser
Blazing Member
What the HE double hockey sticks was BRP thinking ??????? Loaded up the trailer (heading to Americade ) ,hitched it to the Spyder start her up and do a circle check, notice the rear red marker/clearance light is out.:gaah:Oh guess I will pull the bulb and get a replacement, while 20 minutes later I find out its a sealed unit WHAT THE HAY. 30 bucks for a replacement. Even if it was a bulb It took me a good 20-30 minutes to pull the light and then put it back.
One of mine was out when I picked my trailer up at Cowtown...or at least by the time I got home. Warranty replacement but it required two trips to the dealer and ten days in between to wait for the part, plus 15-30 minutes to install it. Lots easier if you can just replace a bulb. Same situation with one brakelight on my 2011 RTS and on my HMT from ESI. If one section goes out, you need a complete, expensive, and time consuming replacement. They replaced my taillight assembly under warranty, but my HMT is still wounded. That will be a gigantic pain to replace! Technology isn't always an advantage...it has a cost.
