RT Oil Change video suggests using a different sized Torx!? - was it wrong?
JKMSPYDER
I was watching a video on changing oil on a '21 RT. The rider said to use a 45 Torx on the left side and a 40 Torx on the right side. I am currently on my third Spyder and the right-side plug has always been a 6-point Allen key. Was this guy mistaken?
Yes, he was mistaken. And that's how drain plugs get stripped out. Clearly a Torx - T45 - and clearly an Allen - 6mm. Otherwise referred to as a hex bit.
Yes he is wrong. It may work for him, but sooner or later he is going to have to deal with a stripped-out Allen head (hex key) plug.
Of the three Spyders I have owned I have immediately changed out the OEM plugs to hex head plugs from goldplug.com. Worth the money and headache.
If it was a YouTube video see if you can find it. Add a comment letting viewers know they need to use an Allen wrench.
