RT-L Liner weather strip torn away from liner - any fixes?
vetman03
Just bought a 2013 RT-L. Great deal in excellent condition, low miles. In the frunk there is a liner that has the BRP logo on it. I cannot tell if this was a factory item or added afterward. Anyway, around the top edge is a U-Channel with a round rubber tube that was glued to it. Just about all of the tube has torn away from the U-Channel. It was a weatherstrip or cushion that touched the underside of the frunk lid. I cannot find anything like a part number of either the original insert, or just the weatherstrip to replace it. I may get some Gorilla glue and try to carefully glue the tube back on to the U-Channel.
Anyone else have this situation? Any other ideas on replacing or repairing this weatherstrip?
That's an OEM part. Neoprene seal. Item number 330.
https://www.canampartshouse.com/oem...27e8404f638/body-and-accessories-front-fender
Yes, an after market seal may be less money.
Hey, thanks for the quick response and information. I can take it from here. Thanks again!!
I had checked Spyder Pops and Lamonster already. Somehow missed this site completely in searches.
I have a 2010 RT SE5 with the OEM liner like that and I have re glued my weather stripping on several occasions. I used Weldwood contact cement and it holds up pretty well.
That frunk weather strip seal on my Spyder gave up the ghost not quite a year ago and I replaced it with one from Spyderpops for $22.95. The best thing about Harvey's replacement is it's just a bit stiffer than the OEM one, so when I turn the key to unlock the frunk the seal serves as a spring and the frunk lid unlatches by itself.
