RT Dash Accessory Bar.
johnny canuck
I hope someone can point me in the right direction. A long while back I remember seeing someone was selling a chrome or stainless bar that attaches via those two bolts on top of the RT dash. I believe it had spyder cut out in it. Can someone remember who/company that was. Been looking ---- but no luck.
Thank's in advance
Johnny.
Dash mount
Thank's in advance
Johnny.
I think this is what you are looking for. This is the one I have.
http://store.valueaccessories.net/SpyderRTDashMountRAM1BallCompatible.aspx
Thank's in advance
Johnny.
With the sun behind you the reflection/ glare might be a bit much. The ones you can purchase above are flat black. I painted the aluminum one I made---- plane and simple----works perfect.
Lew L
Here is a picture of the RT Dash bar that I have :
Dash bar mount 001.jpg Flat dash bar mount.
I bought the above from JT Thornton I have a 2014RTS-SE6.
Deanna
I ordered from TRICLED
I ordered mine last week, had it by Friday, had it installed in less than 15 minutes on Saturday. Added a Ram Mount 3" extension along with a Ram Mount X-Grip for my phone.
dash mount
I bought one of these and installed it on my 2015 RT-S. Easy to install and love the way it looks. I have one problem that I figure can be solved. My ram arms will not tighten enough on the slick ram balls that came with the dash mount. As I drive the arm continues to slip until my GPS is bouncing on my dash. Anyone else experience this?
Take a pair of Vise Grips, and wrap the teeth in a piece of denim...
You'll be able to grab the knob, and give it a serious twist with that setup! :thumbup:
I've lost ALL strength in my hands, and this trick works for me...
Make sure the balls don't have aluminium threads. I twisted 2 right off doing this.
JT’s dash mount here.
I had attempted to use just Ram mounts to get my Zumo 550 up and over the dash but the long arm was an inch too short. JT’s Dash Mount adds a spacer that moved the Ram ball up enough that the Zumo plate misses the dash. Perfect.
