Replacement for OEM "Raised Bars"?
Matahead
I just read about replacing RS bars with ST set-up. Our 2009 has what I presume is OEM riser. Under the ignition switch is a flat rectangular piece that looks to cover a triangular three bolt clamp on 7/8" handle bars. The bars are about 29"wide, 3.5" rise, 4" pullback.
The parts guys at the two shops I visited have no idea who or what the current setup is on our RS. Cruising EBay, I found 1" risers that have Can-Am packaging & logos.
Because we do not have original set up, I'm hoping someone here might know which bars I could use to increase rise, possibly width. I ordered, picked up a ERGO bar. Unfortunately they appear to be same dimensions as those I have now. I think I need 6-7" rise & pullback, 32" width.
Thanks,
thom
YOUR HANDLEBAR SET-UP
I'm pretty familiar with handlebar set-ups ...... but I don't understand yours :banghead: .... It would be a BIG help to everyone concerned if you could post some pics or get someone to post them for you ....there are many ways to do this .......... In regards to the OEM riser options NONE of them will do what you want ........ Mike :thumbup:
Thanks,
thom
Like Mike stated a picture is worth a 1000 words. Then we might be able to point you in the right direction.
David
Are your current bars one piece? Or do they look like they've been cut in a Z or multiple pieces? Again, a pic is worth a thousand words.
Unknown Bar set up
This is a regular handlebar. Just a single hollow pos tubing.
Those was sold by Kewl Metal, which is no longer sold. Should be 7/8" handle bars. I would go much wider due to cable and wiring issues. Try and find a set with a little more rise and pull back. They should bolt on like regular MC bar once the cover is removed. They use offer a 5", 7", and a 9". Here is a video on it.
David
Thanks,
thom
Don't know if they still sale them but look here for the 7" bars
http://207.150.204.201/product.asp?pid=9401&str=0
David
Helibar riser plates. Also discontinued but you may be able to find one on eBay. I use these in place of the stock 1" riser block from Can Am.
http://www.ebay.com/itm/HeliBars-Ro...ash=item25889a228f:g:B~oAAOSwhcJWIn7s&vxp=mtr
Will bring your current bars 1" higher and 4.5" closer
David
Hey David,
Thanks, I think we have the 5" rise, 3.5" pullback version. I found and ordered a pair of bars 7" rise & 6" pullback. They arrive today or tomorrow, we leave for a long weekend ride Friday, so I will play with them soon. I also sent a message to the Kewlmetal I found to see if they are the same folks and if they have the proper dimensions for the 5" & 7" bars. I noticed the description states 5"7"9" pullback, but that is actually the rise measurement.
