RT Handlebar Installation on ST - measurement data
pauly1
SpyderDeb was one of the first to receive a transplanted RT handlebar on her ST. Although the ST and RS/GS are now history, I figured there are still riders out there that may benefit from the information. Before I did the handlebarectomy, I measured the width, rise, and pull back of the stock ST and RT bars.
ST RT
Width 32 32.75
Rise 5 7.125
Pullback 4.5 6.5
As you can see from the dimensions, the RT bars are higher and come back toward the rider, without going overboard on the width. Reach-challenged riders typically don't have wide shoulders, so the width is important.
Everything fit (major bolt holes and wire harnesses) and lined up during the swap except two of the 4 bolt holes that hold the perforated plastic guard plate to the underside of the handle bar: a simple file job elongate the holes and allow the bolts to be inserted and tighten was all it took.
So if you're looking for a different handlebar set for your ST and ST-LTD, seek out a color matched (black or silver) handlebar someone removed from their RT. The set we bought included the GPS mounting as a bonus!
Now I can through my paper notes away....
Wayne
Good to know....
I assume that all the cables and wires were long enough though you do have to remove zip's to allow for the added length of the bars. Know we had questions recently about this so it is a great help....:bowdown:
