Replace Clutch Lever Question
Kariblay
Ok...trying to remove th stock lever to replace with an ExtremeKempy lever:
1. I removed the circlip,
2. Hit the bottom of the lever pin mildly to see if it would/had moved - no cigars,
3. The pin looks like it may be threaded????
Any advice?
Thanks....Karl
just did mine last week the top of pin has grooves in it put your hand on top of lever and tap pin on bottom with hammer dont forget once pin is almost out hold clutch piston in with finger then put new lever in place ....cal if needed 603-401-2760
How hard did you have to hit the pin from below?
You say to hold in the clutch piston as I remove the pin/lever...any other 'gotchas' I need to know about?
