CLady
Ok, I have a couple things going on here and I need some clarification before I try and figure out what the actual problem is. I am long winded and like to be thorough, sorry in advance.
I have a 2013 STL SE5. I bought it in 2015 and took it to my local dealer to do an oil change and a look over. They said the head gasket needed to be replaced. There was no smoke at the time but I had them replace it under warranty. It took forever and they ended up having to replace the drive belt (I think it's called) also because they damaged it while it was there. They also tore one of the spark plug boots so it was arcing and tried to blame bad gas for it idling so badly and dying at stops. I took it to a different dealer several hours away a few times and finally got the plug wires replaced on my dime once they figured out what the problem was.
A year after that I had a neck injury and haven't really been able to ride since. From 2016 through now it has only been ridden a handful of times. My neck is getting better and I wanted to see if I could wear a helmet and ride again. I got a new battery yesterday because the old one was completely dead. It started up just fine first try. I noticed smoke out the exhaust and waited a while giving it a few revs to warm it up and burn off the condensation. Still smoking. I don't know how long it needs to run before it's completely warmed up though. It was smoking when I did ride it two years ago to bring it to where I moved to. Was at least a 35 minute ride so it should have been warmed up enough then. I didn't notice the smoke when I was riding but my ex, that was following me, said it was smoking. I had to stop messing with it yesterday because it started raining and I keep it in a bike barn outside. I wasn't able to really tell if the smoke is white or gray so I don't know if it's from the head gasket going bad again or if it's burning oil.
After I turned it off I checked the oil and it wasn't even registering on the dipstick. Went back to the local dealer and go a couple quarts of oil since I'm not sure how low it is. The oil that they sold me is XPS 5W-40 4T synthetic blend with an API SM rating. I checked the operators manual and it says not to use API SM because it can cause clutch slippage/damage. I checked the BRP website and this is the oil they have available there. So, first question is, should I use this oil? I assume that since it's what is available on their website that it's ok to use? I didn't see anything else available there.
I just now checked the coolant and it's a little low. Bright green, not brown. I'll get some coolant to top it up.
I'm going to guess the answer to my second question is a no but I'll ask it anyways. Can having really low oil cause smoke from the exhaust?
Lastly, if it's burning oil how far can I ride it on the highway before it'll seriously damage the engine? I really don't want to take it to my local dealer after the fiasco of the first service there. If I can find someone to follow me so I can get back home I'll consider taking it where I did before to Lifestyles in Mt. Vernon instead of the 10 minute ride from me. It would be anywhere from 76 to 136 miles depending on the route I took (ferry or no ferry). I don't know anyone with a trailer that could take it there for me.
Any advice would be appreciated.
