Removed add-on lights - now Tail Lights don't work?! Ideas?
sledge
The Spyder I traded for last summer had some stick on lights on the top rear trunk lid. The wires were around the hinge of the lid and I took them off. I cut them with wire cutters and now the tail lights dont come on. BUT, I'm not really sure they were on before I cut those wires. Also, the wires were not connected to anything - the only place they got power from was the Cig. Lighter hole inside the top trunk. I have checked all the fuses, nothing is bad. Anyone have any idea on where the Cig. Lighter hole gets its power??
Open both saddlebags. Remove rear panel. Trace down to where the lights tied in. I’ll bet you find the problem. Torx 30 screwdriver is under the seat in a toolroll. If you have to , remove the black lower fender screws, let it swing down. Remove and unplug tail lights. Inspect wires. There might be a flasher module, which frequently is the problem. I’m available Saturday. Call if you need help. Joe
thank you very much , I am an retired Diesel Mechanic , but there is a big difference in a Kenworth and a Spyder ... LOL I have been trying to find Where to look for it more than what to look for . I really thank you for your Service too . I will check this in a few days , and I'll let you know what I find. Thanks again .
