No tail lights or brake lights after installing LED's - any ideas?
Accord911
I took off my fairing to paint it and put it back on. I then put some led lights on it. Now I turned the key and dashboard. I pushed on the Cluster and the gauges started working. I notice my tail lights are not working. On the right fuse block, the second to the last fuse makes the third to the last fuse come on. I'm need help.
Just a thought, might not help any, but it could be worth a shot... :unsure:
LED's will only work if they're connected with the polarity wired the right way, so if you've reversed the polarity on them by installing them backwards, they won't work. Maybe you should try swapping them around?! ;)
Hmmm, the way I read this it sounds like you have done some wiring that is not kosher on those LED's where they tie in for power. I would remove that connection and rethink how it is made and/or move it to another lighting source...
Maybe you should clarify the above statement, as it does not read well. Are these new front LED driving lights? Did you cut into wires and splice things? Fuse block statement is about as confusing as the other statements.
Isn't the lighting on the Spyders a CANBUS? If so and you spliced wires or took signals incorrectly, it could cause this.
Got it.
So, unless the added lights are turn signals, no effect from CANBUS.
