Redneck solution to oil spill
Saw these guys on a TV show about this. BP could also be using their fleet to siphon the oil off the surface. Another cool thing that has been done before is to use a certain microbial fungus that eats the oil--- and leaves no residue at all.
At this point they need to try anything and everything.
Yeah, but they deplete the water of oxygen which causes dead zones. There's no good way out of this mess.
:2thumbs::2thumbs::2thumbs: BP stated Louisiana isn't the only place to get shrimp....maybe they should listen to the BUBBA GUMP'S :yikes::dontknow:
Hats off to these guys! :bowdown:
This is about as GREEN a solution as I have seen to this mess. :2thumbs:
MM
Thats awesome. I have seen the oil first hand, monitoring it for the last month to avoid transitting in the heavier areas. And, no matter what BP claims, its real bad and just getting worse.
I heard they actually came up with a much simpler solution to stop the leak all together.
Someone figured out if they drop a wedding ring on it, then it will stop putting out. :D
