Rear wheel soot?
Normal soot
:spyder2::spyder2: Normal brake dust......
I have started noticing something and am curious if others have noticed. My rear wheel is getting covered in a fine black powder that looks like soot. The wheel in the pictures below were cleaned approx 500 miles ago. Is this abnormal? I have almost 14000 miles onthe Spyder and have never noticed this kind of filth so quickly.
View attachment 44186View attachment 44185
Sent from my A500 using Tapatalk 2
I have not noticed much brake dust on the Spyder, but I used to get it bad on a Kia Sportage I used to own. I switched to ceramic brake pads and it eliminated dusting altogether.
First I would make absolutely certain your drive belt is tracking correctly, and if it is then I'd switch to brake pads that don't leave dust. I don't have a recommendation because I haven't needed to replace my pads yet. When I do I will shop around though and get some that will do the job. I'm pretty tight with cash, but I don't skimp when it comes to brakes.
Belt alignment is good, no issues there.
After a decent ride; do the rear rotor or caliper feel "hot"?
The pads always rub on the rotors, That's the way there designed, So they'll always feel hot after a ride, and i assume that on a ride at some point in time you'll have used the brakes to slow down and stop which will also heat the pads and rotors.
