Funnily enough Mike, the tire suppliers here tell me this 225/60R15
size is more popular in the States than it is here in Oz!! :hun: But you certainly could be right about it being a 'different availability/different spec' thing, altho the KH17 is a reasonably common size/spec tire here, being one of the more used comfort/ touring size/specs for mid/high end vehicles; still, it shows up as an acceptable tire size/spec for use on a fairly significant range of vehicles, including GM, FORD, Cadillac, Nissan, Toyota, Mazda, & a bunch more including European makes... :sour:
As for the differences in tire size, that's one of the traps of using tire size calculators rather than doing a direct comparison. I did a direct comparison, & the Kumho Solus KH17 225/60R15 at 28psi on the stock rim came in at 22mm larger rolling dia than a new Kenda 205/50R15 at 28psi on the stock rim, which is within the specs for easy handling by the Nanny (especially when teamed with similarly larger front tire sizes plus my generally running a lower pressure in the tire - bigger bag needs less air to carry the same load, & at 22-24 psi the speedo is spot on accurate!!) How can this be so? Simple really, tire manufacturers don't all use the same baseline or sizing conventions, so a nominal sized tire from one manufacturer may well be somewhat different in reality to the same nominal sized tire from another manufacturer!! Hey, the same sized tire but with a different tread could well be different in rolling dia/circumference even if the tires are from the same manufacturer!! Some use the tire carcass or casing as the basis for sizing, some use the case plus a nominal tread thickness, others use casing plus actual tread thickness; and then there's all the differences that running different air pressures or even running the same tire on a different width rim can bring!! :banghead: And yeah the Nanny hasn't objected to this sized tire AT ALL; in fact, if anything she likes running this sized tire on the rear with 175/60R15's up front even better than she liked running the stock spec tires all around, with less needless interference but even more impressive braking & handling/steering than the Kenda's ever achieved as well as a mire comfortable ride - but they are a heavier construction tire with higher specs in wear, speed, & load carrying; and I do have a BajaRon bar up front too!! So there's less scope for loose or sloppy handling & better traction/handling to start with!! And as a result, these tires not only feel/behave better, they have already lasted significantly longer than the crap the Spyder came on!!
But you may be right about fitting the bigger tire under the ST fender Mike!! (& others) I hadn't thought of that when I posted first, but the RT fender
is higher/further away from the top/rear of the tire, with the closest point being up front at the shock mount/swing arm pivot end; while on the ST the fender wraps around the rear of the tire from the axle end of the swing arm - so it might pay the OP to measure very carefully there before spending the $$ on a 225/60R15 & then finding you need to toss the fender to get it to fit!!
pps:
