Radiator Fan - Pre 2014
So Roger....what? Did I get you thinking? No response to the idea?
Or are you thinking about doing it ;)
Bob
So Bob, Jerbear and I will be up to your house and I'll tear into how that reverso-fan thing actually works.
What tools should I bring besides my 4 lb mall and 30 inch Stillson?
You better bring a sawzall and some plywood to patch any holes you have to make, while exploring . . . :roflblack:
I think some 2013 owners may want a product like this.
BUT you are correct. Someone needs to test it manually to see if it helps or not before R&D goes into something like that.
I also do not have a heat problem so I would have no desire to do it either. But if someone wanted to make a product (if it worked) I think they would have a lot of sales :)
Bob
Interesting reading here--and way out of my league. I will just sit back and watch. :popcorn::popcorn:
Is it just me, or has anyone thought about where the 2014 radiators are located in relation to the 2013 location. I've only seen photos of the front of the 2014s with the fans showing, which looks to be more forward to me than the 2013s (??? not sure). If you just reverse flow of the 2013 fan, where is the air going? Is there a good flow forward, and a short enough distance to get the hot air out the front?
Don't see a problem with forward flow. Providing the spyders forward motion is 20 mph or less. That's just my opinion however. Inflow shouldn't be a problem either. Tho, those who have cut holes in their swops would likely pull engine heat. If, they reversed the fan flow. Jmo
Driving directions
by adding a simple Accelerometer you know the driving direction and the acceleration.
No need to tap into the computer.
This is what's so cool about this place; "Collective Brainstorming"
:chat:
.. even with folks who aren't directly affected, but want to help out! :clap: :2thumbs:
