beachbumPC
Just upgraded from a 13 ST-S SE5 to a 15 F3-S SE6. It has 2900 miles on it. Compared to the shifting on the ST-S, the F3 is smooth in the gear changes but you can hear a clank when the gear changes. RPM or acceleration changes when shifting result in the same sound. The oil level is correct and I just ordered a Lamonster oil change kit to see if fresh oil will help. Any suggestions?
Also when I rolled backwards into the street this morning, I went to shift into 1st and it wouldn't. I put it in reverse and backed up but still wouldn't go in 1st. I pushed it into the garage, started it back up and it shifted into 1st without hesitation. I rode it for about 20 miles without issue. Anyone ever experience this?
THANKS,
Beachbum
THANKS,
Beachbum
