Question for those with the Bluetooth Dongle.
bcoulter19
Once this is installed does it allow you to bluetooth your phone to your headset also. I wasn't sure how this would work.
Thanks,
Bill C.
I guess it might depend on the kind of headset you use.
If you have the Sena SMH10 headset, then, yes, you can still receive phone call via Bluetooth.
The phone will override any other device (radio via dongle, GPS or intercom) while a conversation is active.
Likely yes
You did not share what type of headset you have. Most headsets can pair with more than one BT device. With a Sena headset for example you would pair with the dongle as your stereo music device and pair with your phone in handsfree mode, with 2 hands free mode slots left for other devices.
I have a scala g4.
The scala g4 will connect to the phone with out any other dongle, It is blue tooth at least mine were. If you have a manual it is described in it on how to do. If you don't have manual you could get on scala web cite.That is if your phone is blue tooth.
