spyderdave
In my (limited to 8K miles on a 2020 RTL) opinion, get BajaRon's swaybar. I won't go as far as to say it will resolve issues passing a semi at interstate speed, but I found it stabilized my RTL in corners & curves, specifically curves that tighten or are unevenly surfaced. This opinion would be "seconded" by my wife, who commented on how much "correction" I was doing IN a curve (pre-BajaRon swaybar). Now my RTL gets a "set" and requires little, or no, correction; I consider it money well spent.
I would be quick to add that BlueKnight911 probably has a handle on the true "root of the problem"; the angle of the coil-overs on these machines. I just don't have the education in suspension geometry, or experience in fabrication, necessary to compensate for the factory set-up..., so I bought a swaybar.
Also..., remember that tire pressure is very important. Radial tires tend to move horizontally, or "roll over", because they have flexible sidewalls intended to afford you a softer ride. The lower the pressure, and the taller the sidewall, the more they will do this. If your running car tires, at a lower pressure than manufacturer specs, this has to affect your steering/handling; to what degree, I don't know. I put 16" wheels & tires on mine & am happy with that decision.
