Problem installing Custom Dynamics Third Brake Light install on 2014 Spyder RTS
My luck isn't doing to well starting off on my mod installations on my new 2014 Spyder RTS. It appears there has been some changes to them compared to previous models. The custom dynamics kit uses BRP type connectors for the third brake light installation. The problem is that the factory wire connect you can't reach as it is probably zip tied and can only see it with a flashlight.
Looking for the best way to get access to this connector either by removing the rear fender or the side bag. Before I dive into this would like to hear some feedback from others that have done this mod on their 2014 Spyder.
Thanks,
Shawn
Removing the rear lights allows full exposure to the wiring plug your talking about. Just make sure when installing the lights, you put the light protrusion back in the bottom slot.
