iSpyder
I have been on the search in the forums for anyone who has installed a Powerlet outlet in the spot that is under the left passenger hand grip (where the 3/4" covered hole is). I wanted to start a thread to see if folks have any input. Here are a couple of my questions:
1. Is the hole the correct size to accommodate the Powerlet outlet? The Powerlet instructions say the hole needs to be 11/16 inch. The hole under the hand grip is 3/4 inch. Are the nuts that come with the Powerlet large enough to cover the slightly larger hole without a problem?
2. Is the left passenger handle grip pretty easy to take off and does doing so allow a person to get tools in there to fasten the Powerlet? Thought I would ask for any veteran advice before I started experimenting
Thanks in advance for any input...
