Powering Accent Lighting
I want to add accent lighting above the front grills. Rather than running the positive lead from the battery, is it feasible to use an Add-a-Circuit adaptor plugged into the right hand fuse box position that was vacated when I switched the fuse to an adjacent position to have constant power to the power outlet in the trunk (using it for the Battery Tender) ?? If I do it this way, the accent lighting will be on whenever the engine is running.
Sure....
Thing would be if it would all clear and the cover will fit back on snuggly to keep things water tight....:lecturef_smilie:
I wouldn't do it that way. Too many potential issues with leaking fuse box to begin with. Tap into an existing lighting circuit at a watertight connector using an adapter such as this one TricLED included in one of their lighting kits;
Fuse Box
I had thought about the improper sealing of the fuse box, but thought that I'd wait until I was ready to begin the project to see if I could make it work (maybe with a grommet??). Thank you, gentlemen, for the input.
Check out a power distribution setup like an Eastern Beaver PC-8, use a relay to supply power directly from the battery. This will give you 6 switched and 2 always on fused circuits to power whatever you want.
john
If you use the Show Chrome 13-311 fuse block the relays are built into the box. Then you can add anything you want without an issue.
