Power Buss Install
frank3
RT-S PE#0180
Installed a power buss on my 2010 RT-S. Chose to install it under the seat so that I'd have easy access to it without removing body pannels. Not enough height clearance under the seat for the buss so I removed the plactic pannel over the left side, top of the gas tank, cut an outline of the buss in the pannel to allow the buss block to be mounted directly on top of the gas tank with all weather mounting tape. Thanks to Riverside Doc for the power relay that I used to feed the buss so that it's switched.
Final Install.jpgAll Weather Mounting Tape Applied.jpgLocation.jpgOutline for Cut.jpg
