Patch cable for Freedom trailer to RT?
IMO, it is just plain dumb to have the vehicle connector not as close to the hitch ball as practical. The ball is the swivel point, which is where you want the hinge point in the wiring to be. I could hardly believe it when in another thread the topic of locating the connector came up and under the saddlebag is the designated spot. Just plain dumb. One of the very few truly dumb things the Can Am designers have done! :banghead:
I agree it's a dumb spot. But if you run an extension from there to the hitch close to the ball, but not close enough to get pinched. Then if and when you remove the hitch. The wire extension can be unplugged easily.
That's a good thought. That's why I'm going with it.[emoji106][emoji887]
Just keep in mind the movement in the swing arm. Make sure the wire is long enough at full droop. If you want to check that. Jack up the rear from the frame.
Figured that's why dealer stopped at underside of bag.
