Oops, hooked up battery backwards! Anyone done this?
1hillbillybuddy
hello, between my father and me we hooked up the battery backwards on a 2010 RT . we heard the fan running, and then smelled smoke.
then hooked up battery correctly, then got zip pop noise , and then alot of smoke. i assume it was the power regulator. and who knows what else we might have damaged. i was posting to see if anyone had done or heard of this , and trying to get a jump start on getting this thing going again, thanks for any input. have a good day.:opps:
So sorry this happened to you. First place I would check is the main fuse. Not sure where the fuse box is located on a 2010, but hopefully the fuse did it's job and sacrificed itself!
Fuses typically blow in 100's of milliseconds which isn't fast enough to protect modern electronic devices. In the last half century EE designers have learned to put a device, typically a diode, in the path to block reverse current and sometimes a second device to short circuit the wrong-direction current and blow the fuse. Unfortunately, bean-counters often see the protection devices as an unneeded expense and they are removed from the design.
Let's hope Can-Am has reverse connection protection. Otherwise it's going to be a very expensive and unhappy day.
Smoke is Bad
:chat:...Electrical Smoke is ALWAYS a Bad Boy.
So Sorry for your issues with your Spyder.
Good Luck with Your Mission and keep us posted.
..:thumbup:
