I think you are at a point now where you need to give it a "functional test" and if it works similar to what it did before, then be happy that it's fixed.
Did the compressor blow a fuse when it failed ? If so, maybe it took something in the charging system with it......like a diode in the regulator.
Did you actually re-activate the LEDs ?
If you can find a cheap battery powered "transistor" radio, it might make a good noise detector to try and find the source of your noise.
Good luck.
P.S. This has been going on for so long that "Mr. Murphy" says something else might have happened during that time that has nothing to do with the compressor failure.
Functional test performed today -- and I was right the rhythmic static overrides the ability to receive without static..... BUT, only if I am moving. If I am sitting still I have about 1/2 to 3/4 mile transmit and receive ability with decent clarity (about as good as it was before the compressor was replaced).
BRP actually had the dealer hook up the LEDs when the CB was replaced (and I had hooked some of them back up before the compressor replacement myself). Note that this noise was present with ALL LEDs unhooked and I was unable to receive without static ... so I am still looking at something other than the LEDs. Additionally, I have added ferrite beads to all the LEDs to mitigate noise and chose a "wide band" type to cover frequencies likely to interfere with the CB.
We may actually have an old transistor radio around somewhere .nojoke... not sure it will actually receive anything, but might still work as a noise detector.
Wouldn't any noise present also affect the AM band of the BRP radio? :hun: I am able to receive AM, FM, and NOAA just fine (no static).
Yes the compressor blew a fuse .... but so did the heated grips after the compressor was replaced (pinched wire in the heated grips circuit). For the compressor replacement, then entire back of the bike has to be removed .... including the rear cargo module. In order to do this, there are a large number of components that must be disconnected. Note that the rear portion of the entertainment harness is routed around the back of the bike just underneath the rear trunk and looks to fit into a channel. What if something was not properly plugged back together? What if a wire was pinched in the entertainment harness (won't be the first wire this "tech" pinched)?
I sent the recording to BRP customer support and they have passed it on to the technical team -- I am going to let them tell me what the next step is. Have made it clear that this dealer doesn't have the means to test the CB and seems unwilling to spend a few dollars to do that (a hand held and a headset is all they need).
Finally ... hubby dug out an ancient SWR meter (J&M suggested checking to see if the antenna is damaged or no longer tuned properly). Also, I am down to pulling fuses and checking for the rhythmic static with the motor off. So far I have pulled:
- The compressor / horn / heated grips -- F5 right box
- The fuel pump -- F8 left box
The noise persists :banghead:
Next will be the turn signals ... all in an attempt to isolate the problem. I suspect, however, that the offending component is IN the same portion of the wiring as the CB itself (say, the entertainment harness). Maybe when we remove the Tupperware to do our SWR check, I will take a close look at the instructions for CB install and check all the pluggable components myself. I have taken the Tupperware off enough times now that I no longer have to look at the book (not sure that is a good thing).
Sigh .... at least we had a good ride today -- not going to let a bad CB ruin that. Beautiful day -- 150 mile round trip for lunch.
hyea:
Thank you for the suggestions .... will keep this thread up to date as things progress (or degrade) .... Ann
