myronmathis
I have a 2011 RSS and it seems to me that it uses a lot of oil and it doesn't get the MPG (35-42MPG) that I was sold on. Does anyone have these issues?
Sorry but I don't buy this.. I have 65000 Spyder miles including 32000 on my 2012 Rt LTD.. I ride like hell is chasing me and need the elka shocks that allow me to take 30 mile per hours curves at 60. I have never had to add oil between changes on either of my bikes.I have been told and I personally believe ALL Spyders use oil. How much depends on how aggressively you ride. If someone tells you their Spyder does not use oil either they do not ride it or they do not check it. IMHO.
How many miles between oil changes? Did your oil level stay constant between changes?
I would say you're the exception and not the rule regarding the engine not using any oil at all, if that is what you're saying.
I have a 2008 GS SM5 and get around 31 mpg. The mpg I get is around average and will vary on your driving habits.
What is a lot of oil? I was down about a quart from my last oil change, which was 3500 miles ago.
I live in Mt Airy, Ga. and I had the same problem my 2011 RSS. First of all your getting oil in your air box and the stock paper filter now has oil on it and that's not good. The oil comes from the engine vent, that the hose that goes from the rear cylinder head to the air box, and puts dirty oil into the throttle body and that not good. I have a list some were that all the things I did to solve the problem and get better gas mileage. The best gas mileage was 44.6 mpg and I average 38 mpg. PM me and let me know if you want the list. Were do you live in Ga. If your close I can show what I did.
Mike
Can't prove this, but I've seen a few filling oil level to max instead of midline and that appears to push that extra oil to the airbox. Owner responds by refilling to maximum only to find more oil in airbox and oil level below max.
I target the center of the dipstick between min and max. No oil loss or oil in airbox
I have put 62,000 miles on these things. MPG is roughly 30 miles per gallon depending on how you drive, how you calculate, whether you use ethanol blend. Oil consumption is about 1 qt every 5,000 miles. I would guess a significant portion of this goes up through your air cleaner and gets burned with intake air or it leaks out of the bottom of the engine. Both of these numbers will suffer if you drive really really hard.
It gets burnt before it can get to the air filter...
Just to add the throttle body's are down stream from the air filter...
