Three Spyders over a five year period for a total of around 35,000 miles and I have
never damaged an oil plug. The secret is in using the proper tools, and using them carefully. Use a hex bit socket on a 3/8" ratchet. Remember that most Spyder oil plugs are hex, not torx. Push the socket firmly into the
cleaned drain plug, and hold it there firmly with one hand while you work the ratchet with the other. Be sure and use a torque wrench to snug the plug back down, to avoid overtorqueing and difficulty removing it next time. Replace the copper crush washers periodically, they work harden with age. Even a hex plug can be damaged by poor or improper tools or the wrong technique.
