I have a 2014 RTL. Ever since my last oil change, about 6 or 7 mos. ago, after a ride I will get several drips of oil on the floor under the right side of the engine. After a few times I determined that the oil level was a little high and I drew off enough to get the level to the halfway mark between full and add on the dipstick. I followed the manual precisely to check the level. Even after removing the excess I still get the drips. There is no oil showing around the dipstick housing, the oil filter housing or around the oil plug. If I damaged one of the o-rings putting the plug back in, could this cause the leak? Or does someone have another idea?
Thanks,
Ron
Thanks,
Ron
