Oil filter torx screw size
IdahoMtnSpyder
Well-known member
Does anyone know right off what size torx driver is used to remove the engine and transmission oil filter covers? I can't remember what size they are, I'm hoping to avoid taking off the tupperware, and I can't find the info in the service or owner's manual. I want to order a long, 6", 1/4" or 3/8" drive torx driver to use there. My friend had one when I changed the oil last fall and it sure worked great to get to those screws.
Torx
40 and 45------ even though there was some discussion about a 6mm hex drive on one of them.
Keep us posted.
Kaos
Torx or Hex
Both filter covers on my '12 RT are 5mm hex. I bought a set for 3/8" drive, 6" long, with ball ends. Works great for other fasteners on the bike too.
Both drain plugs are 6mm hex.
Mike in KY
Depends..!
on the V-twins they are 6mm hex heads. If semi auto the length is different on the trans filter and engine filter...keep them seperate or do them one at a time a mixup can be a pain. There is no torque spec's for them so I snug them up and give them an extra quarter turn...:thumbup:
Mike in KY
You got it right! Decided to take the cover off anyway since I needed to check the oil. 5 mm for the filter covers, 6 mm for the drain plugs!
Sorry about that??????
I should have looked to see which :spyder2: you owned. I just through of the sizes for mine. Guess I used to the V-max forum---- The basic bike hasn't changed for over 25 years:yikes:
Kaos
TORX-----HEX ---WTF
Be advised forget what everyone has to say about this. BRP in their infinite WISDOM has put several different combinations of HEX AND TORX on various oil drain plugs...........Use a mirror and a flashlight, because if you get it wrong and completely strip the THREADS it is very very expensive to fix..........just sayin....Mike :thumbup:
