Oil cover tupperware blowing off
Thank you Peter
Hadta take a pic or two!
The second picture angle isn't great, but it does show the clip well; the first is from a bit further away & the clip is not quite so visible. ;)
Got the pins today, installed on both panels in less than 10 minutes. Thanks so very much for the information and the pictures.
Pat Clark
Parts to Order
Just had an oil change at a dealer. Noticed the next day the right panel was GONE! No need to ask them, they are not too bright. Surprised me the right side was gone, as there is no need to remove it on an oil change. Looking at ordering the replacement parts now. The schematic is a bit fuzzy to me. It appears I need the panel, the chrome piece and a plastic clip??? of some sort. Is that all? Looking at the remaining panel, is appears so.
Thanks.
I had the cover blow off the left side some months back, replaced the rubber grommets, put shrink tube on the pins, installed stainless steel lanyards on both sides. I'll be damned if the right side didn't blow off yesterday on I-95.
Has anyone come up with a fix for this? Screws or better yet a turnlock arrangment like they use on aircraft panels? This is getting way too expensive not to mention aggravating.
Thanks, Pat
Velcro
Thanks.
Found no clip, just a torx screw. Thanks!
Thanks.
I'm assuming from your user name that you have a 2012 RT Ltd? If so, from the 12 RT parts list it looks like you need 13, 14, 15, 15a & 16 (just be sure to get 13 in the correct item for your color)
