Oil change 12 months, YES or NO
So I'm new to this, I picked up my new Spyder 2 weeks ago, I have a total of 600 kms so far on it. So should I change the oil before I park it for winter? I'm hoping to keep riding as long as I can but I live in Canada and winter can come over night lol
Yes, change it annually if you don't ride much! I just purchased mine with less than 1800 miles but is a 2013, just purchased oil, filters, coolant and brake fluid to change next week before I put into hibernation for the winter.
Cheap insurance - and isn't it listed in the maintenance schedule anyway?? Along the lines of scheduling an oil change annually, or at the indicated milage, whichever comes first? For the minimal cost & effort, why not? It's certainly gotta be cheaper than replacing an engine or gearbox... :dontknow:
Unless you know the dealer/po changed it before you got it, I'd change it as soon as possible.
My dealership changes the oil yearly, when my spyder is in hibernation( Oct. to April). It is easier for me.
Deanna
Deanna,
I live south of you.The temps here are definitely trending downward, and the daylight is getting shorter. Can't imagine what it's like in Vermont. Got an appointment on Oct. 18th for my '15 RT Limited's "end of season" annual service, and oil change. This will be the last annual service for it under any type of warranty. My BEST warranty expires on April 2020., while it's in for it's winter nap.
I've had zero mechanical issues with my Spyder. Needs a rear tire before next riding season(15,000+ miles).That's why I'm on the fence about looking at a 2020, even though my 70 year old hips are having a hard time with the seating position on my '15.
Mike
Why would you say if the dealer changed it? It is brand new and oil will not break down that fast from not being used. As mentioned only 600kms so far. People are saying yearly. I bought it in end of Sept so what to go by is, change it out before end of season next yr. Oil subjects have always been a long debate I know been in a lot of them lol.Thanks
Mike T,
Here in Vermont, the temps are also trending lower at night( we have had a frost in higher elevations), and the daylight hours are also getting shorter( in Nov. we turn the clocks back an hour). This Sat my spyder goes in for its looooooooooooooooooooong winter nap/sleep. So the dealership will change the oil/filter, rings, etc. put it on a battery tender( which I supply) and do the fall prep.
Deanna
Deanna,
Mike
Mike T,
I replied to your post on posts #27 & 28 on page # 2 on this thread.
Deanna
One thing that has occurred to me.... whether the oil has an infinite life in the crankcase, what about the filter? The typical oil filter is made of paper, cardboard, and glue... I wonder if the filters have a "use-by" once put into service?
Sorry, must have missed that part. I usually buy used so it just becomes one of the first things to do.
No way would I dump out oil with that low of miles. As stated earlier, that oil (and filter) will be perfectly fine come spring. Just make your last ride is one that will fully heat up your oil. I'm curious to see if anyone has had a catastrophic engine failure due to oil, other than not having enough in the motor? Has anyone had warranty denials for having low mile oil in for over a year? Can-Am has to prove any oil related issues. Keep receipts of oil/filters and mileage records.
If it were me I would change oil now
Thanks
Hello all,
I have a 2018 F3 LTD. I had an oil change at the end of the season last year at 5000 kms. I thought BRP recommended an oil change every year irrespective of the mileage. I currently have only 10000 kms on it at the moment. I contacted my dealer for an oil change and he said the next service is at 20000 kms only.
What do you make of this
J
I bought a kit. I will change the oil myself when I store my F3 for the winter:(. I contacted BRP but the answer is too vague.
Oil Change
:coffee: I do an oil change every April because I usually get about 5000-6000 miles annually.....:thumbup:
