Oil analysis @ 3 years & 9500 miles.
I always thought the additives in an oil blend were there to prevent any bare metal exposure.A barrier if you like to any contaminents with the filter doing the chunks.:dontknow:
Yes, that is what they do............ and they lubricate so good that the clutch will slip if you use them in a wet clutch engine.
A little confused on your statement. Are you speaking of your oil change, or the OP's? His was at 9,500 miles. 200 miles beyond the manufacturer's recommended service interval of 9,300 miles.
Ron, Here is his own words: Oil is in great condition even after taking 3 years to get to BRP recommended interval of 9300 miles.
Maybe I misunderstood what he wrote. I thought you were supposed to change at 9300 or annually. Guess I better read my manual.
I got to it, and passed it by 200 miles!
If the Rotax engine was a completely closed system, so that no air could get in, and no air could get out, then it would not run. Air has to get in, and more importantly, exhaust has to get out. I am pretty sure the engine does not always stop at a position where all valves are closed, if that is even possible. Valve cover vent and dipstick are not air tight. If the engine was completely air tight, it would be weeping oil at every gasket on it. The pistons displace air on every revolution, and that air inside the crankcase must have some place to go.
I should have been more clear. I meant the crankcase is pretty much airtight. As far as air displacement by the pistons the air from one piston coming down will be pulled by another piston moving up. Without going through all the calculations I think the only case where air volume in the crankcase changes would be in a single cylinder engine.
One thing that I have learned with over 30 years in the maintenance field is that "Most" people will disagree with just about anything concerning motorized vehicles.
Especially, Oil, Tires, Service Intervals, Antifreeze and Fuel Mileage. :coffee:
Ron, what is/are the pathways and sources for moisture to enter the engine? The reason I ask is if the source is air then moisture won't enter the engine unless there is a pathway and the engine is in an environment where it's temperature fluctuates in sync with the ambient temperature. What happens is when a (supposedly) closed container sits outdoors and warms up in the day the air inside is partially expelled due to expansion. Then at night when it cools down and the air inside shrinks more ambient air is drawn in. The cooler air drawn in carries more moisture than the warmer air that is expelled, resulting in a gradual build up of moisture inside. But this scenario is predicated on the closed space having some venting path to ambient. We had this problem with valves and such being stored outside in Louisiana when I worked for the Dept of Energy. It was nigh impossible to wrap them tightly enough to prevent 'breathing', and so they would rust internally.
As far as the Rotax engine is concerned I think there are two reasons why moisture is not drawn in. First, the engine is close to airtight so air isn't going to be pumped in and out. Second, most Spyders, I dare say, are stored in the winter in a fairly constant temperature environment. What fluctuation there is in temperature is either so little, or of such short cycles, the engine is quite unlikely to fluctuate significantly in temperature. That's why I think the issue of moisture buildup inside the engine is an overblown concern.
Engine is not air tight, valve cover breather goes to air filter hose.
Iron at 214 ppm
Viscosity at 13.6
Moly and Boron present.
I'm surprised no one has said you can't use an oil with Moly or boron, both friction reducers.
I'm not that guy, moly is in nearly every oil formulation, auto or motorcycle/wet clutch.
You be you. I see a 30 weight oil that has quite a bit of metal in it.
It was due to be changed, and I'd still take the side of 5k changes max in anything that uses the engine oil to lube the gearbox.
No harm done short term, but CanAm only cares if they get you past the warranty period without an engine fart.
There have been articles posted about Rotax engines used in aircraft and one of the biggest takeaways from the article was the engines need to be run and not sit for too long and water can accumulate causing internal rust issues. Ill see if I can locate it.
The geometry of the engine does lead to positive and negative pressure pulses in the crankcase.
The fact that the connecting rod is connected to a central position by the wrist pin at one end and an eccentric crank pin at the other means the acceleration of the piston up from bottom dead center and down from top dead center is not identical for a piston, which is why 180 degree twins have both primary and secondary vibrations and not just the secondary vibrations as you would think. The piston speeds are equal at TDC on one and BDC on the other (i.e. 0), and at the half way up or down mark. In 120 degree triples like the 1330 cc Rotax the geometry is even more complex as you have three pistons doing this at 120 degree intervals so you still get pressure pulses. This is accentuated by any piston blow by and increasing engine temperature adding a constant positive pressure component.
If this doesn't make sense, draw out the position of the piston crown in a diagram for a single cylinder engine at every 10 degrees of crank rotation, you will see what I mean. Speed down from TDC is not the same as speed up from BDC. It's just a function of geometry. I didn't believe it until I drew it out on paper. This is what makes crank balance weights and auxiliary balance shafts a complex compromise.
In humid climates the situation of moisture gaining entry to the engine is primarily because when the engine is hot, the moisture pulled into the engine by crankcase pressure pulsing is boiled off by the operating temperature of the air in the engine. However, when you stop the engine, as it cools, it draws moist ambient air into the engine as the internal pressure decreases.
In some climates, like in the North of England where the air is cool and moist, over a period of weeks the engine can start to exhibit emulsification as water droplets condense out in the engine and appear as milky droplets in the oil. As long as it isn't too bad, this is all boiled off as the engine started and run up to temperature again. However, over the winter if not used for months, enough oil can drain from from surfaces to leave moisture to lightly rust some metal surfaces. However, this is a function of temperature and humidity of the climate and I've never seen it here in dry as a bone Utah. But in some climates a spring oil change is better than a fall oil change as far as an annual service is concerned.
Idaho -- do you know if your oil analysis addresses wet clutch friction plate materials, which I believe are probably organic resin? I didn't see anything like that on your analysis. Thanks for sharing.
You're right. After the initial 3000 mile oil change, per the manual, it's every additional 9300 miles or 1 year. Whichever comes first.
Old post. But the manual recommends changing the oil annually because it is just boiler plate advice. Some lubricants will not protect the engine from rust or corrosion while in storage. The manufacturer cannot control which oil you use so they err on the side of caution. However, it's been proven that Amsoil will protect for several years. And there are probably others that will as well. I tell my customers that they should honor the 9,300 (Or thereabouts) mileage recommendation. But not to worry if it takes more than a year to get there, if they are using Amsoil. I've proven this with my own machines. And this is the only reason I make this recommendation. Though others have verified it for themselves.
But, if under warranty, it still might be wise to change your oil yearly. Might help avoid a hassle.
Absolutely! And save ALL receipts. Friend with another brand motorcycle with an engine problem went to the dealer for warranty. First question that the dealer asked, "was the oil changed regularly"? He had all his Amsoil receipts, oil and filters. Warranty fixed the bike. :thumbup: Tom :spyder:
Idaho: The viscosity of the oil, at 13.6, was still in the 40W range so it had sheared very little.
Agreed. 13.6 converts to almost 38 weight oil. Not bad when you consider that the BRP blended oil shears to around 20 weight between 4,500 ~ 5,000 miles. That's why your motor may get noisier and shifting changes may occur as you get into this mileage.
This is a great chart for converting these numbers.
https://bobistheoilguy.com/forums/threads/cst-vs-sae-viscosity-table.50764/
A worthy consideration. Though to deny warranty, the manufacturer must show cause & effect. If the oil tests out at or above the manufacturers recommendations, even at 2 years, say. I'm not sure they could make the case that a failure occurred because the oil wasn't unnecessarily changed after a 12 month period. Afterall, what is the purpose of the 1 year change interval if not to keep the oil within specs? If it is in spec., then where's the rub?
BRP knows the limits of their lubricants. I'd say the recommended service interval is a reflection of this. Though it is still a quandary as to why they recommend running nearly 5k on 20 weight oil.
While I agree Amsoil is one of the top oils, my wife has 2015 RT Limited with 70,000 miles and my 2015 F3S has 60,000 miles. I have done all oil changes at 9,000 miles with the BRP kit. Both have been trouble free and never use any oil between changes. Noise and shifting is fine all the way to change time. No recommendations to others, just my experience. What's great is we all have the freedom to use our choice. Also, if you do some research on Blackstone, their fuel dilution and viscosity results can be suspect.
I've used a number of oil analysis companies. Results were similar. But I've been using Blackstone for years now as I find their service superior to the others I've tried. I have always been very happy with them. I took your advice and did some research. I found a good number of positive reviews. But nothing negative. Can you provide a link to the information you are referring to?
It is my understanding that these companies use pretty much the same, industry standard, testing processes. In my experience, the numbers vary only slightly from company to company. What I like about Blackstone is their explanation of the data.
