OEM heated grips AND fog lamps failed on 2015 F3s - Please help
mkuszek
I have a 2015 F3S and the OEM heated grips AND fog lamps quit. They were on one day and the next day would not go on.
I have checked all the fuses visually AND with a meter - all good.
I have changed the shedder relay with 3 other same new relays.
I have swapped the Accessory lights relay with my headlamp relay.
Everything else on this bike works perfectly including the headlights, horn, and all controls.
I took off ALL the plastics and checked the fog lamp bulbs - all good.
The 2 switches that have to be pushed to turn on the heated grips and the fog lamps BOTH LIGHT up when depressed/turned on.
All wires look good under the switches.
Can anyone shed any light on this problem or if it is both the switches somehow, then how do I get the plastic they are mounted on removed to change them?20210905_112353.jpg
Have you checked your manual to see if the heated grips and fog lights are on the same circuit? If so maybe they share some wiring that has chafed of broken?
I don't have a manual. Spoke to the dealership today and they said it may be a broken wire. But they cannot get it in for a month!
You should purchase a Manual. They have simple line drawing wiring diagrams that a labeled with the wiring color codes. I use a Midwest Manual.
