Can the heated grips & fog light pushbuttons be changed for toggle switches?
KYJim
Can the heated grips & fog light pushbuttons be changed for rocker switches?
I have a 2015 F3-S. It has heated grips and fog lights. The switches are push button. Has anyone changed these out for rocker switches? The rocker switches would be easier to operate with heavier gloves on. Thanks!
I recently added two more push buttons, so I had the cover off. There is a fair amount of real-estate under the switch bezel, but you would need to be careful on the location and depth as the tolerances are fairly tight, especially around the key cylinder and antenna assembly. Measure 10x, cut once... seriously. :thumbup:
:cheers:
Here's an image of 4 switches on my 23' F3-S. I thought of larger rockers, but I needed 4 switches... If pushing them becomes an issue I would consider adding aluminum spacers on top of the actual button top so they stick up a bit higher.
