Bob Denman
Is that what they're calling condoms today? :shocked: :roflblack:Gosh, Bob, looks like you missed it..."Shop supplies: $26.00"
Perhaps it's because these fluids die with time instead of miles? I know some coolants gel with time and stop flowing; I've had that happen in a car.
But I've never heard of brake fluid replacement before... even with automotive brake jobs they just bleed the lines and add new fluid as needed. However, if it's to maintain the integrity of the Nanny's ABS and especially VSS then we shouldn't question it. Does anyone know? They should just tell us! Intelligent minds would be satisfied with reasonable explanations.
And "adjust the valves?" What, you mean the Rotax doesn't even have hydraulic lifters? (Hmmmm, moboy sez to self... maybe that's why it's possible to red-line that baby at 9000 rpm...? Check!)
Both of our RT's had rears replaced and the price for the tire was $138. Labor was a little high because they had to R&R the trailer hitches and replace rear pads.. still got out of there for under $200. Sometimes I think dealers use dartboard pricing!
Wow...for my rear tire it was $200 for tire 2 x $110/hour + ride on balance = $500!
This whole service deal preys on fear. Changing the coolant and brake fluid at 14,000 miles is insane. How the hell is any of this maintenance necessary on a spyder but not a car? If your dealer wanted you to change brake fluid or antifreeze in your car at 60,000 miles you'd laugh at him and walk away so what's so magical about the spyder? The engine isn't overheating right? So the coolant must be doing it's job right? The brakes work so the brake fluid must still be in there and working properly. There is no way in hell that the brake fluid is going to solidify and quit flowing IF it magically turns to **** it will only make your calipers hang up and not release fully. I'm probably going to take my $1,000+ and put it into a spyder longblock fund and roll the dice if i ever get to 14,000 miles. If you pay the labor on the brake bleed procedure tell the dealership to spend the money on a power bleeder and a class on how to use it :banghead:
ARCTIC,
I kind of get where you're coming from; but if you think of the maintenance as a way to prevent these issues from popping up... :thumbup:
You really don't want to wait until the bike is along the road and peeing coolant, before you think about changing it... :shocked:
I bet if i pulled my $1,000 out of my pocket that i didn't spend on maintenance I could find a nice ride for me and my spyder :roflblack::roflblack:
... The brakes work so the brake fluid must still be in there and working properly. There is no way in hell that the brake fluid is going to solidify and quit flowing IF it magically turns to **** it will only make your calipers hang up and not release fully...
