OK gang please share your ideas. I have a non-BRP trailer with the standard 4 wire harness that I have been trying to wire to my RT. I have the factory hitch and wiring harness including the bike to trailer harness. I have been using a Hopkins 3 to 2 wire converter (2 different ones and they are not powered). When I connect everything as outlined below I get the following results:
White - Ground
Brown - Tail lights
Green - Right turn
Yellow - Left turn
Red - Brake light
Wiring is connected as follows:
Bike black to trailer white (ground)
Bike brown to trailer brown (tail lights)
Bike green to trailer green (right turn)
Bike blue to trailer yellow (left turn)
Bike red or orange to trailer converter red (brake light)
It doesn’t matter if the bike is running or not I get the above results. I also checked the individual wires on the bike trailer harness and they all seem to be functioning as they should and no fuses are blown or missing. The trailer wiring alone is fine when connected to my Dodge pickup thru the factory “flat 4” connector and all the lights on the trailer are LEDs. At this point I am ready to hang 2 more lights on the trailer and wire up individual turn signals, but I can not see the reason the above isn’t working. Any ideas?
ray:
- Normal tail lights
- NO brake lights :yikes:
- When I turn on the turn signals (either side) both the RT’s tail lights flash (only the center LEDs, but I do have normal bike and trailer signal lights
White - Ground
Brown - Tail lights
Green - Right turn
Yellow - Left turn
Red - Brake light
