blacklightning
Well-known member
What are the dimensions of the supporting area on the rack?
I'm looking forward to the fight over ordering one!![]()
Question: What will the waterproof container cost? :dontknow:
Bob, I can't believe that you would challenge me to a fight over this!!! I am shocked, shocked I tell you. :joke: That's okay, I will let you be the first to order. But if you ever come down to North Kakalakia, it is on!!!!!!
Do you feel there will be a rusting issue where any of these parts meet ? (Not positive of how this would assemble) Thanks.
What happened to this ? I can't find anything new or a place to buy them.
I had to break away from building these to finish up the inside of my new shop building. I needed to get heat in and move a bunch of stuff out of the machine shop so I had room to work in there. I was hoping with winter here no one would need one. I'm about 2 weeks away from finishing the work on the shop building then the plan is to finish up the first batch of NHR carriers. Last task is to insulate the roof and the wiring on the west wall. Putting itch up on the bottom of the roof is a slow process...
View attachment 142526View attachment 142527
JT
man, even Trump would be tired following you around :roflblack:
What is the completed weight on the unit? Also do you know approx weight of the box that goes with it to figure the resultant amount of weight that might be added to remail within suggested weight on the unit?
Thanks!
Looks good though!
