no headlights
IMSPARKY
:yikes:Was on a nice warm ride in Fla . Got dusk and as I noticed that I had neither head light. Fog lights are working just fine. :yes: I've checked out all fuses and relays, also checked the connections, was fine. Before I remove the Tupperware to check the bulbs, I'm hoping that someone can give a quick fix? :bowdown: p.s. 2015 spyder rt limited. Hard to believe that both bulbs went out at same time.
HELP:banghead:
Hard to say if all tested out good, might have had a power surge burning out both lamps. Might also verify that the regulator is working correctly. 14.4 volts when running.
