New Fuel Caps
I received mine today, but found the instructions above about opening the box quite confusing. So instead I cut the box in half with a band saw to get it open. Unfortunately this also cut the new cap in half. I was concerned that using glue to put the two halves of the cap back together might do damage to the catalytic converter so I used heavy fishing line to sew it together and found some bamboo to put inside the threaded section to add strength. Unfortunately when I tried to screw the cap onto the bike the cap was a hair bigger than the opening. Sooo, I got some plaster of paris and made a mold of the new cap then converted my gas grill into a foundry which enabled me to melt some iron ore and cast an iron version of the repaired platic gas cap. I used a hand file to sharpen the threads on the iron cap then used the winch motor off my truck in combination with a vise grip to essentially use the iron cap as a giant drill bit to open up the opening on the gas tank. Now the repaired plastic cap fits on the bike but Im not sure I've solved the sloshing issue.
:shocked: Dude... :roflblack: :thumbup:
Hey guy's, is this "fix" only for earlier models. I've got a 2012 RTS SE5 and have not recieved a notice, post card, carrier pidgeon, nada for anything on my bike. Just curious..thx
Hey guys!!!
Got my new spyder gas tank cap in the mail the other day, direct replacement. Out with the old, in with the new.
Cheers from Newfoundland.
