Need decent storage - F3S & roll my own luggage, or F3T?
staneric
I'll be doing some trips and wanted feedback on whether the F3T has decent saddlebags and storage, or should I save the additional cost and roll my own in terms of luggage.
I searched and didn't find this specifically addressed.
Thanks.
What do you mean by that? Either way, the question is kind of vague? The answer would depend on how much you carry/pack? A full sized helmet essentially takes up the right side saddlebag. The frunk can hold quite a bit, but again, that depends on what and how you're packing. The left side saddlebag can't fit a full size(unless it is really small).
There is a decent amount of storage, but extra storage options using the top case (or something similar) is always a plus.
Here's my take. I have a 2019 F3S. I also have detachable Shad side bags, Lamonster Pack Rack-80L top case. Both come off easy, so at the end of my trips, I can convert to sporty in minutes. I also have the Madstad shield, with both a dark gray 14" (everyday sporty) and 20" light gray (touring). That said, the F3S does have the 89t rear pulley. That alone adds about 500 rpms to your high speed rev range. At 80mph, I average upper 20's mpg fully luggaged. The T/L models have 79t rear pulley and windshield/luggage installed. IF I were to do it again, I'd buy the base F3 model, assuming it still has the 79t rear pulley. Buy the cruise control module from Can-Am for about $275. Add the Shad luggage kit (both sides fit my L modular helmet). Get a Madstad shield kit. Sport mode? I seldom use it. Suspension? I upgraded from stock anyways. Power? No big deal. Add a Pedal Commander for better throttle response. Need more? Get a ECU flash/PV3. My .02
Can you put a gear bag like the momentum bag on the back of an F3 and secure it with Rok straps, or do you have to have a rack?
I have the First Gear Dry Pak bags in the 40ltr and 70ltr size. they fit nicely on the back seat with my back rest installed. I have Lamonster's bungee buttons and use two flat bungee cords to hold the bag in place. When I travel the frunk is used for jumper cables, tire repair kit, half cover, and first aid kit.
Tons of motorcycle specific bags on the market if you want to shop. Otherwise, put your clothes in a plastic bag for waterproofing, stuff it in whatever carryall bag or small luggage you have around the house and bungee it on your back seat using the passenger handles you have back there. I like the flat bungee's best. Experiment around your local riding area and by the time you get ready for a long ride you'll know what you want to carry, and how to pack it. Have fun with it. cheers.
I use one side bag for things I might want to get at in a hurry, like a rain suit. The other for cap, phone, wallet, glasses, small stuff. The front for bulky items like shoes, rain cover (an old shower curtain and spring clips work for me), extra clothes, etc.
What you are referring to is only good for the RT. The saddle bags on the F3T are very small. They actually hold less than the shad bags. I have an earlier version of the F3T (2016) and a 2016 F3 Limited. They both have the larger sprocket, which allows for the better acceleration. I also like the additional protection from the weather on the F3T and the stereo. If I was getting a newer model, I would get the F3S, so I could get the larger rear sprocket. I believe the F3 base has the smaller sprocket.
I just did this on my recent 5 day 2k Mile trip with my base f3 using a kemimoto 50l dry bag,an igloo cooler, and my cover with its tote bag. Here is the link to where I documented from beginning to end with what I bought as far as rain gear, tools,and baggage.
https://www.spyderlovers.com/forums/showthread.php?149352-First-long-trip-on-the-F3&p=1636299#post1636299
The kemimoto kept everything dry and it held 5 days worth of clothes, my night bag with grooming essentials and meds, and a spare pair of boots. The revit pacific h2o one piece suit kept me dry, and rok straps kept everything secure while moving.
As an added bonus my Can am tote bag for the Cover doubles as a tote bag for all the personal stuff I needed to access during the trip from the frunk (rain gear, emergency tool kit,wallet, gloves, and vape pen) after I put the cover on to haul stuff to and from the hotel room.
I used a bike lock from walmart that fit through the drings on the bags to secure the bag as well as my helmet on the bag while going into stores / restaurants to the grab bars and backrest. I also used the lock to put through the back wheel/frame at night as a theft deterrent.
attachment.php
I looked at the momentum bag as well as a couple of similar ones from several sites before I bought my kemimoto and it is not waterproof, they only give you a cover to put over it which keeps rain from coming in to the top and sides.
Across multiple sites with reviews multiple people have stated that water comes in through the bottom on those bags even with the cover on.
I went through several strong storms on almost every day of my trip with my kemimoto and everything stayed dry the whole time.
LTD IMHO. The rear case comes off in seconds, and you can put the flat cover on turning it back into the S :) Also can replace the trunk with a number of things.
The Limited and the S are 2 very different beasts. The base and S don't have ANY bags, smaller (or non existent) windscreens, sportier but less "comfy" seats and no cruise control (at least on the base model....I don't know about the S). The T and the L (Limited) are very similar to each other. They both have slightly more substantial windscreens, cruise control, hard side bags and "full" gauges including BRPNo (sorry, BRPGo). The biggest differences between the T and L are the top case, heated seats and floorboards of the L over the T. I've never owned an F3 although if I ever buy another Spyder, I'd probably either get an S or a T as I don't do much/any overnighters. Not sure I care so much for the more elaborate gauge cluster as I tended to BT my phone directly to my helmet.
Please note the 2017 F3T has the larger 89T rear pulley.
The best luggage system ever invented for any motorcycle, 2 or 3 wheels, is a sissy bar and a military duffel bag. Anything else is just for appearance, and probably won't hold as much luggage. Sometimes inconvenient, maybe, but the price is right, and you can use it as a backrest on long trips.
+1 totally agree with the use of a duffle bag on the passenger seat. Easy to strap on and great as a backrest...
