Need a little help on my shock
Savant70648
Need a little help, why is my rear shock in manual mode, when I check the setting on my console it is in manual mode. It use to let me set soft to hard. This is on my RT 2014.
It is in "Manual" mode because of a problem with the ACS system. I would suggest that you check the ACS arm on the left side near the belt to see if it has come loose from the mounting point at the top or bottom or if it is bent.
If you find nothing amiss there I would suggest you look for a "pinched" wire in that area. Good Luck!
KYSPYDER
