Need help finding the ECU location on a 2020 Ryker 900 - any ideas?
Meky
Is there anyone who could help me find ECU in Ryker 900 ACE, year 2020?
I'm checking compatibility of some feature with DynoJet support and they want pictures of the unit.
Problem is I'm having hard time to locate it.
Google is not exactly helpful through traditional search. Gemini says somewhere near the left knee, but not really exact. ChatGPT says right part close to intake.
Guy from DynoJet says close to the fusebox.
And Ryker maintenance manual says nothing.
I'm looking for exact directions, ideally a guide how to get there. I don't want to start striping plastic panels and looking blind.
Thanks for help!
Aaaah, you call it ECM, not ECU. That would explain a lot!:D Thanks.
Clear now. Right hand side, hidden behind the rocker panel. So that needs to go down and then I'll see.
There is no ECU listed in either the owners manual or repair manual so maybe explains your problem locating it? The the term they use is Engine Control Module (ECM). It's located where @StalkyTracker shows it in both my owners and repair/service manuals.
