my first oil change on a 2012 rss se5
mikew1368
so i want to do my first oil change on my spyder but i want to make sure i do it right. i have the kit now im looking to see if there is any sights that has instructions on how to do it. perfurbly for that model appericate any feed back thank you.:yikes:
Lamonster has a video on his site showing an oil change on a RT. While not exactly like yours, it will give a good idea.
What he said...
:agree: It is quite easy and if you just take your time and remember the steps you will do fine. I do suggest you remove and replace each filter (you have 2 on the se5 models) fully so as not to mix up the cover bolts. They are different lengths for each filter and if you install them wrong you can strip or break them off....:thumbup:
