My Cruise control won't allow me to accelerate just by twisting the throttle - Is this normal?
Lctriple
My 2015 F3S won't accelerate when twisting the throttle if the cruise is engaged. I have to shut the cruise off, then twist the throttle. In my experience, that could be bad in certain situations, like trying to avoid a car drifting into your lane.
I thought that was what was happening to mine on my last trip. I finally rotated the throttle far enough to go past the cruise speed to pass another vehicle and when I released the throttle it went right back to the set cruise speed.
My 2015 F3S won't accelerate when twisting the throttle if the cruise is engaged. I have to shut the cruise off than twist the throttle. In my experience that could be bad in certain situations. Like trying to avoid a car drifting in to your lane.
That aint right!
As @Snoking1127 & @Mrmikey have sorta alluded above, we've had a few here who didn't realise that you have to roll the throttle on enough that you take it past where it was when you set the cruise control speed before you'll start accelerating any faster than that set speed - could that be what's happening here? :unsure:
You can try it to see if it's that simply by finding a bit of road where you can set cruise and ride safely for a while, only when you set the cruise speed, don't release the throttle, just lightly hold it in the same place. Then once you can feel that it's actually the set cruise speed controlling the Spyder's speed, try rolling on more throttle to see if it accelerates then. 😏
If it does, then it's normal and all is working the way it was designed - you just have to roll the throttle on enough to go PAST the speed where it was when you set it, which is effectively what all cruise controls do. ;)
Please get back to us and tell us how this goes. (y)
