My $445 Trailer Build
markyodo
I took some of the best information from around the forums (here & elsewhere) and decided to try my hand at building a reliable trailer for our Spyder. The build started on Saturday and I finished this afternoon. I have been working on it a few hours each day as I get the supplies. When we return from our weekend trip I will be adding an LED light to the inside of the trailer and connect it to a pressure switch on the lid.
I apologize in advance if this post is long winded.
First here's a break down of my costs not including registration and plates.
$13.90 Cargo Net http://www.amazon.com/gp/product/B00K73QBKS/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
$3.99 Split Loom http://www.amazon.com/gp/product/B0006301MS/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
$5.81 4 Pole Connector http://www.amazon.com/gp/product/B004BE60ZU/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1
$7.40 Heat Shrink http://www.amazon.com/gp/product/B00EXLLXK8/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1
$7.41 Grease http://www.amazon.com/gp/product/B0077K8WJC/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1
$5.64 Paint http://www.amazon.com/gp/product/B003CT4AQQ/ref=oh_aui_detailpage_o08_s01?ie=UTF8&psc=1
$6.57 Eyebolts and nuts from Local Hardware Store
$9.36 Liquid Nails from Local Hardware Store
$16.07 6x8 Area Rug from the Bargain Outlet (next to Harbor Freight)
$40.00 LED Trailer lights http://www.harborfreight.com/one-pair-submersible-trailer-led-lights-94137.html
$329.00 Trailer from Harbor Freight http://www.harborfreight.com/600-lb-capacity-78-inch-tag-along-trailer-66771.html
Unboxing
We picked up the trailer on Thursday and I took some photos of the un-boxing for those not familiar with the HF Tag Along trailer. The packaging was "ok" the box was visibly damaged but everything was inside and in good condition.
659yQ3Y8UAFSmQ63URTMrDUE52zTbAHHzXGK0hBXo2C
ORN2oLs8oBmWuGst0u09wM0Emzneyi0fv2GuFRnlRtF
no9SQjwiqbubA4FECtajW7Biyu1Ggs38qQfghAnNH8G
h3bmS6uwuHldvTfbdQi9700horIzwib5qeNkWQANW0N
Wheel Bearings
The first thing recommended by many was to repack the wheel bearings. The original state was pretty dismal and the "vasoline" they used was scarce.
I took it apart and cleaned them before applying the new grease and reassembling.
G2nWCvM9reKd4vnvl93TPvqaemO99KCtRRYBWCxJ5oL
Oc6BqRL0d2cmca6nGXACO3omGXx7E2JYYQMzF06xwHs
dmHmnykjlcuQze39QG9OCnKn0P0IPnLfs7tM0SFwB37
KuQi0ngH5A542rBLQKv39GDbUH0BJs1aTbi7IOpCWBK
Paint the Wheels
Next I wanted to paint my rims black to match the trailer and Spyder. I lightly sanded the existing paint and wiped everything clean. I prepped the area with some tape and a plastic trash bag.
jRLDmdcs7KkXz3g6OiLVoYfPEZzzxXHccFE84kuq286
LM0ArKG7gPQM2O9ontO2Y5gDYi5nnBPB4OarKbgnhtq
LRfu7V4ujyjHy0Yn09pwdRHp2RxREv73zE5l5t9afJD
E9zCQewjkODDiN7jBLR5r3wJhNW8BuUlshpvAc01lpL
Carpet Installation
When we purchased the trailer I had an idea that I wanted to try carpeting the inside. We stopped by the Bargain Outlet to see if they had any remnants but what we found was a nice roll of indoor outdoor area rug. I wanted a permanent carpet mounted to the roof of the trailer and removable carpet in the bed of the trailer. I prepped the surface with a good wash before gluing the carpet to the roof of the trailer. Then weighted it with a few small items till dry. I then used smaller strips to complete the wrap around effect on the roof.
Total weight added is maybe 4-5 lbs total. The carpet was really light.
OhJe6Kf4npBgAvcxVh22MvGTi1UrSf12HyXpB2HJ0vF
x4pNmuGSJSE0SbmvguCKIxzPg3dYyUWyZPXTsO4aHLb
The bottom carpet is held on with the eye bolts, and a second piece was added which has slits in it that just slide over the eye bolts. Easy to remove and clean.
7y9zrjCGt79ge7jMXQerPTTTtjIS7BMfG5gFz7Enw4v
JLFY4Sapiwrw06Du31itwTF7o8THv7dni9KRmPwKEb6
LED Lights
I wanted to upgrade the light kit that comes with the trailer and simply based on suggestions and convenience I decided to go with the Harbor Freight LED trailer light kit. The installation was easy and the lights are very effective.
All wires were cut, soldered, and shrink wrapped. Each light's ground is attached to the trailer.
2smzUXdrNHQS09UuBA5GRsQcClmA1BJndAW46vIq3L8
4 Pole Connector
I had to do some research to find this. I found the part on Amazon and it was a simple install. I cut the standard connector off, stripped the wires, soldered the new connectors wires, and added the shrink wrap.
aDfq6jBt9Rigrmr8iEJKGxLusE1XGNbIt3wrCowhXae
Split Loom
To give all the wiring a finishing touch I added split loom. Covering the entire length of the main wire run to the bike, and small sections on each tail light which go into the frame for a short length.
blwdMfQrgGgoe3rfEkUCPe3z8c01wHeJh3JkK3bZGPW
aJESDj4Ua9VMEXDFM6DlXnj2dHcyAwQkDnaTT6oG6M
bkY5Iz8UKIYKXf4Rm2arp9BoHZn0Gp1LAq0CmbVbL1o
Rubber between springs and frame
One part of the install I forgot to take photos of was my placement of high density impact resistant rubber strips between the support springs and the frame. There was quite a gap, I guess by design, and I had read about some others placing scraps of automotive belts in there to help with vibration and sound.
Final Look
Overall I am very pleased with this build. I have taken the trailer out for a few miles and it tows so quiet I had to keep checking my mirrors.
I think it will add huge value to our extended trips this summer.
cSVD617MZBd98Qh4lMz8oG1QGehzPR77USjFGOIRKrX
Jy9E60zjcx5h6jV94wgYhqxo5hPgczyGSojxx4VlnDb
To do - I will be installing the LED light after the first trip, and I am coating the under side of the trailer with some Rustoleum rubber coating to protect the frame and trailer.
Thanks for looking! :f_spider: :ohyea:
Well done..!!
looks like a great build. Congrats on a job well done..:2thumbs: now your all ready and nowhere to go..:roflblack::roflblack:enjoy all that extra space...:thumbup:
Very cool
That is some good work. If you are going really long distance, you could probably find larger diameter wheels, but that might make it bounce more. I am not trailer literate.
Well done.
Leaving Friday morning for a 6 hour scenic trip to Pittsburgh. We will be there for the weekend and the trailer is going with us. ;)
Great Job and very nice write up. I did almost the same thing shortly after getting our RT. In place of the two layers of carpet you used I cut a 1/4" piece of plywood and covered it with the indoor outdoor carpet. I like you idea about carpeting the top. I did change out the wheels to 12" and cut an led light into the lid which is on the brake circuit. I added a battery box with a dual usb charging port and a standard 12v outlet. The battery can run the internal and external LED lighting when the bike isn't running. When I ran the wiring I added a connector to charge the battery when the bike is running. Diodes prevent feedback to the bike when it is off. Since my RT is white I also painted the lid of the trailer in the pearl white to match. The photo shows the external at full brightness which is a lot! I added a dimmer to make it more usable on the road. The internal LEDs run the perimeter of the lid and are on a tilt switch to automatically come on when the lid is opened. Great job (and I plan on borrowing your carpeting on the lid idea).
CJ JAX
You can have the carpet idea, and I am borrowing your LED perimeter idea. I really like that. LOL
Do you have a link or store name where you got your light strips?
Thanks.
GREAT JOB!
That is one great DIY and write up.
I do have only one suggestion..a spare trailer tire. I am sure you can fab a mount to the trailer or the tongue.
I forgot all about that. Yes, it's a must have and I already have the parts available to put one together. Thanks for the reminder!
Trailer Build
Great looking trailer , I have been planing on building a cargo trailer for when we travel and plan on Hoteling it , In the summer season we use a tent trailer and she pulls a dog trailer , but there are times when we take a weekend trip to the coast and rough it in a hotel or cabin and the extra room in a cargo trailer just cant be beat . Guess I'll have to get started !
attachment.php
The first thing I had to do with my Tag Along was strip the original wiring and replace all the Scotch Locks with solder and heat shrink connections, it was eating fuses due to bare wires.
If you go to 12 inch wheels, the 4.80 X 12 will fit, the 5.30 X 12 are too wide to clear the frame.
I like my Tag Along well enough I'm thinking of going with a 500 pound torsion suspension, it'll ride better, and I'll still have less than $700 invested.
john
CJ JAX
Nice Job! The trailer looks like a UFO in the Pic.
