Missing Air Dam Experience
Odie
I installed the Missing Air Dam I ordered and I had the exact opposite experience that everyone else is having. I live in Arizona and spent all afternoon installing Highway Brackets from Kewl Metal and installed the Missing Air Dam while I had all the panels off. I finished everything around 8pm and took it for a spin. Keep in mind that it is 80 degrees at this time, not 110. I got on the Interstate and ran about 80mph and I stayed at four bars. During the day in 100 heat, without the MAD, I can get down to three. Then I exited the Interstate and was held up at a stop light for a couple of minutes and I went to 5 bars and stayed at 5. Then the light turned green and I cruised 45mph and it took more than a couple miles to bring it back down to 4 bars. Got home and pulled in the garage and went back up to 5 bars. The fan kicked on and I let it run for a few minutes and I could not get down below 5 bars. During idle, in the middle of the day, in 100 degree heat, my fan will kick on and my temp will go down to 4 bars very quickly. With the DAM it couldn't get below 5. Anyway, that's my experience. I'm glad it's working for everyone else. Leave it to me to be the first one with and adverse experience. :ani29:
I had a simular experience. I rode down the inter-state about 70 mph and the temp was at 3 bars but as soon as you slow down it will go to 4 bars and when you stop 5 bars now if i get back on the highway it will go back down to three bars but it takes a little time. :dontknow:
I'm trying to understand this, Dead of winter [10f] i run 3 bars, Summer[80/90f] 3 bars, Stopped at a light 4 bars, Long light 4/5 bars, fan turns on at 5 bars.
Any speed over 35 mph 3 bars summer/winter,That's what a properly working thermostat is supposed to do,Keep it at 3 bars at off idle.
Now if i use the Air dam, According to most reports I'll drop 1 to 2 bars if i use the air dam, So in the winter I'll be at 1 bar, summer 2 bars [at off idle]
Can't happen, at lease on mine, The thermostat won't let that happen.
Just my findings, [No new rope please.]
Air dam
I'm with you Odie. Put them on and my Spyder is doing exactly like yours. As soon as you stop in traffic 5 bars. Tested them out yesterday again and the temp. on the bike was 93, real temp. 86. Took bike out and checked my fan, it kicked on at 4 bars. Rode for about 1 1/2 and it was at 4 bars most of the time. Maybe that's the best it's going to get. Maybe humidity has a little play in this equation. Oh well gave it a shot and it is what it is. For $25.00 no lose. Safe ryding
I don't believe the Air Dam unit is meant to help while you're stopped..... only when moving.... that's what the fan is for.
When moving, you should see the temp lower than before---- I see 1 bar lower on average--- but when stopped it's just like before.
From the product website:
"You can expect a lower coolant temperature by a reduction of two bars at speed. This reduction varies depending on your driving habits, ambient temperature and custom tuning."
I believe that BRP now sells an upgraded, more powerful radiator fan.
I cannot help but wonder . . .
Is it possible that -- when not moving, the new air dam adds insulation and thereby restricts the ability of the radiator reservoir to lose some of it's heat by natural radiation?
This addition will clearly force air over the radiator fins AT SPEED -- which should have a noticeable reduction in heat retention.
I installed the air damn last week and at cruising speed and air temp at 82 deg. and lower I am at 3 bars.82 deg. is as hot as it has been since install,but will go up to 4 or 5 bars at a stop just like it always did.It looks like the real test will come in the next couple of days if it gets near 90 deg.
well did the install this morning... stupid simple.... so I took her out for a test ride it is a cool 77 degrees today in Bakersfield and while cruising around town it stayed at 5 bars and while on the highway it dropped down to a cool 4 bars. So far im not impressed it is running 1 bar higher than normal....
Diggittt
Mine reduced by i would say a bar while moving. i wondered myself about applying foam to the radiator if this would "insulate" it. i havent noticed much of a difference around town. I can see that it may increase the effectiveness of the fan by drawing more air from one side of the radiator and throuh it, but again I havent noticed a difference in town. I have not noticed an increase though as you guys are reporting. At speed above 40 mph noticeable difference. If you ride in town a lot this mod might not be "necessary" for you. If you travel on the highway it makes sense to me and in my opinion it works
:agree:I reported two weeks ago the same experience on this forum. I thought I was sooo alooone.
Interesting about the isolation and increased (more then normal) heat at a stop.
:popcorn:
I understand it should get warmer when you are stopped but by leaving the dam off, the cool air goes around the radiator and i'am sure this has to help keep the bike cooler also i guess what i'am trying to say is what damage is happening thats a big jump i think to go from 3 bars to five bars in about a minute. also by not having it you ride around on 4 0r 5 bars and don't have that big spike in temperature. Please don't be offended the air dam does do what it says it will do no argument their. And does anybody notice the hot air on their leg from this i really though i burned my leg. :dontknow:
I would think you would want the cool air to go through the radiator not around it. the surface area of the fins is much more effective than the side of the thing at cooling. When at a stop the fan pulls the air through it. The dam may prevent cooler air being pulled from the back side of the radiator and force warmer air from in front of the raditor (since that is where the engine is) through casuing warmer temps but that has not been my experience. It seems to me the dam should increase the effientcy of the fan but I couldn't prove that either. Thats really the only way I could see this being the reason for the bike runngin warmer than it normally would by using the dam or because of an insulating effect weve already discussed. As for heat on your foot I still have stock pegs and dont notice any change there. Sometimes for me it depends on which way the wind is blowing. If the wind is blowing right to left as you sit on the bike sometimes the hot air from the cowling seems to "blow" back onto my leg worse than when there is no wind. I have never been burned but if I had floorboards I could see it being a potential issue.
If the air dam was doing what it was designed to do and it does then the fan should not come on at all. Now if i ride without the air dam yes the bike runs warmer but the fan does not kick on because the temp is more consistant. As with if i leave the air dam on yes at high speed more air gets in the radiator and cools it down but when you get in town driving the temp goes back up to 4 or 5 bars then the fan kicks on. So which is better for the bike i really can't say. Maybe remove the air dam and run a switch to the fan or leave the air dam on and still run a switch?
UPDATE
Rode home from work yesterday and ambient air temp was 89-91 deg.At cruising speeds had 3 bars showing so I believe the air dam is doing what it was intended to do.As you can see from Lamonsters' post these engines are not running too hot.My concern is not damage to the engine from heat but problems with all the electronics housed inside the tupperware.Imagine the heat build-up on a hot day after riding for awhile then parking in the hot sun.We have had problems with our cnc machine controllers in our shop on real hot days when the boss was too tight to turn the AC on.Several weeks ago after riding in 90 deg. + temps stopped for lunch and when we went to leave the air temp on the Spyder read 101 deg.Started it up went 1 block and the check engine light came on.Pulled over shut Spyder off and scratched my head (wtf).Waited a couple minutes started it back up,no message and been riding error free since.
:dontknow:
The faster you go (To a Point) the better the MAD works. So your engine is running cooler on the country roads and highways and thats worth the price of admission to me!!
In town its always going to get hot and the more you sit the hotter it gets.:hun:
To me the key to enjoying every aspect of the Spyder is to AVOID congested routes as much as possible.:D
I,m totally happy with the MAD!!
All the experiences are going to be different. I don't have fancy gauges but I do see the bar indicator. All I can say is that city or highway driving my temperature is more with the MAD. I showed less bars in stop and go, or interstate driving, without the MAD. Less bars mean less hot. I'm not knocking the product. If it's working for you than that is awesome! I live in hot Arizona and I remember someone posting the experience they've had with the MAD in the desert. I think I'm better off without it. Just my honest opinion. :D:ani29:
